AngryEvos-Back To Boost Build Thread!!
#76
Nothing better then coming home from work and realizing all your time was well spent! FP Fairy came by and delivered my cams FP5R cams
Thankfully These are the last needed item to complete the longblock. Still need some odds and ends but everything is pretty much wrapped up motorwise! Next on the list is the turbo and fabwork.
#79
I would be curious in seeing the process for validating the head can handle those cams. I know FP is very particular about checking and verifying valve train measurements. I got in two sets of fp4r cams on Friday so it's good to see you got yours too.
#80
I was going to go with another companys cams, but since the specs where "top secret" I decided not to use them. Would my piston dishes have enough clearance for the valves using the perticular cam? Most likely, but I wanted to make sure they everything was spot on so went with the FP5RS.
#86
Turbo swap!
Needless to say I think I have fallen in love
Ball Bearing T4 6466 .84 a/r v-band out
^^6466 is engraved in the housing sorry for the horrible pic
Next up...start fabbing up the FF manifold this weekend
#87
Finally, been checking in all day for this update bud! I can finally read the graph now instead of my tiny *** cell phone pic where i was squinting to see what was what.
Looks like you got the baddest turbo out bud! Cant wait to see what it does on your build! Keep the updates coming! Going to be one bad dd evo!
#88
Awesome, I was so tempted to pull the trigger on the 6466 but didn't want to without any results on an Evo. I got a smoking deal on the 3794 that I couldn't pass up, that's pretty awesome that it spools earlier, makes more torque, and slightly more power. Have your cake and eat it too
#90
Its on a Supra but same concept. I think its capable of sum 9sec passes with a solid trap speed. I guess we will see what happens
