R/TErnie's Evo 9 2.2L 4G64 EFR7670
#287
My schedule has been sliding horribly to the right. It's not for lack of effort... it's due to high levels of optimism. I'm going to re-baseline the project by the end of this week. No specific track date that I'm trying to make.... it's Washington so it's not like it's really nice until June/July lol. I tentatively think I'll be running and tuned in about a month. Hopefully I come in sooner, but I have some other things I need to do as well, which will push out the timeline.
Yes lots of unicorns. LOTS of unicorns.
UPDATE
So after looking at my phenolic radiator end tanks next to my turbine housing... the poor placement of the upper radiator hose (even if it was better than my OEM radiator) and the fitment of the core relative to the core support... I got a hold of Chad (CBRD Speedfactor) and talked to him about getting a radiator made. After a bit of discussion it was determined that I should model the radiator and send him a drawing. So I did Here it is! Thanks Chad and Brent. I'm super stoked to have a radiator that fits the bill perfectly.
A picture from a few weeks ago. Took the car outside and snapped a few pics.
So I made some brackets for my oil cooler. I made 2 of them out of Titanium and 1 out of aluminum (I got lazy yes)
This one removes the steel bracket that usually holds the oil cooler... and I used the fender bolts to make a support rod.
My Second Ti bracket...terribly tough to see when it's on the car.
My little aluminum bracket I made. It's .080 flat stock and .035 aluminum tubing.
Shot of it mounted a LITTLE further back lol.
Here's my new bumper support bracket since I removed my crash beam. .035" SS 1/2" tubing. works like a champ. I just need to make another for the other side. Might jig them up and give a bunch to ER... or I can not paint that unicorn!
Here's a shot of the aluminum radiator bracket I made with a tiny grommet. Waaaay lighter than all the other bs available for radiator brackets. I really like these. I'll sell them with this radiator so I can help pay for my CBRD unit
Here I changed some fittings on the catch can setup. I swapped the 30 degree that was on the valve cover with the straight that was on the catch can. This routes the hoses much higher and helps me clear a way for the UICP.
This shows where I want the radiator hose to reconnect. It clears my intake pipe by a small amount. I may buy some titanium tubing for my upper radiator hose since I don't want it to transfer a bunch of heat to my intake pipe. Makes me think about coating the intake pipe too...or putting a Ti shield on it to keep the heat from the radiator soaking the pipe.
A quick picture of the manifold installed with the downpipe. This will help me locate a few things and think about where I want to place the wastegates.
Shot of the start of the downpipe
Another shot of the manifold
A pic showing my wiring Cluster****. *CF*
Side shot of the engine bay in its current state.
This is how I have the coolant lines ran to the turbocharger. Note that the fittings are blue with black hose ends... I took the Hard Ano-Black hose end piece and put them on my red and blue fittings because I ran out of 90 degree AN fittings lol. I kind of like they way it looks. I also swapped the Red hose end caps on the black fittings...those look pretty nifty too!
Pic showing how the hose is routed.
Pic showing the hoses connecting to the hardlines.
Picture of my Intake Filter location this is what i plan on building a box around and using the inlet from the front bumper to pressurize for pushing my location on the efficiency islands back to the left when I'm doing 120 mph pulls.
3.5" to 4" coupler and then a 4" aluminum tube. I need to make a nice bracket to hold the intake... it surprisingly hangs in space quite well.
My Oil drain line with flex joint. Tube and Nut AN fittings on both ends. Freaking gangster. Thanks Freddie for the flex pipe and the Tube and Nuts. This took a lot of work. I bent the .035" SS 1.2" line with my Parker bender and tig welded all the little fittings and nuts on. Very cool IMO.
4 attempts with aircraft stripper and some sand blasting. Powdercoating is tough stuff. I need to clean these wheels up so I can get them painted/coated silver... so I can put some MH slicks on them or my 245 RE01rs. Nice dyno/drag wheels.
I opted to get some nice hardware for my turbo to manifold connection. Bought some ARP 12 point bolts with nuts.
My blingin new CCW center caps. I had s2k centercaps since I bought the wheels used. S2k's use a 70.x mm hub bore and a 64.x hub bore... so I needed Evo 67.1mm hub bore center caps.
UPDATE
#289
1 Post
So obviously it doesn't count for anything, you could have been painting unicorns.
Unfortunately I've been doing alot of unicorn painting lately and now the weather is nice and my car isn't ready to go play track. When does your Microsoft Project schedule for this build have you hitting the track, I assume you have a milestone for that.
lol!!
#293
Thanks again Fred!
Nucci, I'll probably need my scales in a bit. LMK when/if you'll be up this way and I'll get them from you... or when I'll be down south.
Today I'm going to...
1) finish the -6 coolant lines and cut them to the proper length.
2) Make the hoses for my oil cooler lines.
3) Make a rubber isolated bracket/tab for my 4" intake tube
4) Connect and route my oil feed line
5) Cut and weld on my wastegate flanges onto the turbo manifold
6) Fabricate both dump tubes
7) Route the downpipe under the oil pan.
8) look at my -8 Fuel feed line a little more and figure out what the hell I'm going to do.
9) Think about swapping my 60 degree -8 fitting that is on the FPR to a 45 degree -8 fitting so that the regulator is square to the cylinder head.
10) bend the Ti bracket that holds the FPR so that the FPR is level with the valve cover
11) *reminds me of something I didn't take a picture of* I need to weld on mounting tabs/nuts for the FMM and make a new bracket to connect to the transmission.
*I made a Chromoly front cross member... it's pretty cool. I'll snap some pictures of it tonight when I take some more pictures. new spin on an old idea.
#300
But yeah I just wanted to ask since I didn't want to buy a 10 pack, maybe I should look at other places besides ebay
