EVO-BOSS Ultimate Street EVO build 2012 (nemesis) - MAP power :)
frist update 12-05-2012(( the seats arrived)) post number 15''
2- update ( 27-05-2012) 3rd page post number 38
New interior update on post number 39
update 29-05-2012 on post 44
last update 19-06-2012 5th page and posts number 62-63
New update 24-06-2012 post number 68
last update ( page 8 - post 120 )
Hi everyone
OEM Axles
torque salution full engine mount
EXHAUST
MAP 3'' dawn pipe
Megan full turbo back
MAP T4 twin scroll manifold
SUSPENSION
fortune auto 500 series coilovers
OTHER STUFF
cusco roll cage
Bride seats carbon fiber
carbon fiber mirror
front carbon Lip
rear trunk carbon lip
JDM black rear til light evo
and alot
All other parts are coming on the way , It will be here next few days
so the car would be soon on the dyno and I will keep u guys updated .
People I need to thank :
ADAM for all the efort and help he has provided
MAP team for a good job and great customer service
Chris the owner of MAP
Scott@AMS for a super great head and fast shipping
Mellon for some parts
and big thanks for all the guys over here .
Hi everyone
Well I think it is the appropriate time to finally make a build thread! I have Owned this white EVO for a little over 11-10 months after when i have reached my goal on my other black EVO (( https://www.evolutionm.net/forums/ev...alot-mods.html)) , so My name is sa'ad from Kingdom of Saudi arabia and my Evo name the " nemesis " For some who has never seen my car . 6-7 months ago I ordered new MAP EF4 + S2 cams kit + megan turbo back exhaust and run it on the car , the car was stock with 29K miles .
then we dropped it on dyno to see how much power it will make
the big problem I did (let my mechanic tune the car after when he came from tuner school at australia ) so after a second run
all that was on just 17psi , TONs of knockings and he destroyed my engine
so I've also had a lot of advice, help, and input from Adam @ MAP . Many many many many thanks to Adam he helps ALOT and he's the best one I have ever worked with .
so finally we made the order and the goal is 850whp+ street car .
And this is my setup
ENGINE
MAP stage2 4G64 2.1L
O-ring block
Wiseco HD1400
MAP rods 156mm ultimate duty
MAP L19 Head Studs
ARP Main Studs
OEM Water Pump
OEM Oil Pump
ACL Main & Rod Bearings
Cosworth High Performance Head Gasket - Mitsubishi Evo
IV-VIII 4G63 (2.0L) Bore = 87mm T ~ 1.3mm
Head
AMS CNC head
Supertech +1mm valves in and out.
GSC beehive valve springs w/ ti. retainers.
Manganese bronze valve guides
GSC S3 cams
AAEM Evo 8 & IX Black Tru-Time Cam GearEM cam gears
Gates Racing Timing Belt
Sightglass Clear Cam Gear Cover
TURBO SETUP
MAP T4 Twin Scroll Turbo Kit
6766 BB PET
Twin Compgate 40 Wastegates (Black
T4 Twin Scroll
V-band Out
1.10A/R
SP Cover
Fuel system
FIC 2150cc
FIC Resistor Pack Delete Plug
Full Blown Dual pump hanger
Twin DW300 fuel pumps
Deatschwerks Install Kit
8an Black Braided Fuel Line
MAP Fuel Pressure Regulator kit
buschur racing fuel rial
ELECTRONICS
AEM 2 ECU
AEM 5bar map sensor
AEM 52mm Oil Pressure Digital Gauge - 0~150psi
AEM 52mm boost Digital Gauge 50psi
AEM 52mm AFR
Ignition system
SparkTech CDI Basic COP System / EVO 8
Spark plugs
Intake manifold
AMS F1 Intake Manifold
Boomba Racing 75mm Throttle Body Evolution
Boomba Magnus Throttle Body Spacer
DRIVETRAIN.
QM 8 Leg 7.25” Twin Disk Clutch - race friction w/ heavy flywheel
AMS shifter bushings
OEM Transfer Case
OEM transmutationthen we dropped it on dyno to see how much power it will make
ENGINE
O-ring block
Wiseco HD1400
MAP L19 Head Studs
ARP Main Studs
OEM Water Pump
OEM Oil Pump
Head
AMS CNC head
GSC S3 cams
TURBO SETUP
6766 BB PET
T4 Twin Scroll
V-band Out
1.10A/R
SP Cover
Fuel system
FIC 2150cc
ELECTRONICS
AEM 2 ECU
AEM 5bar map sensor
AEM 52mm AFR
Ignition system
Spark plugs
Intake manifold
DRIVETRAIN.
OEM Transfer Case
OEM Axles
EXHAUST
MAP 3'' dawn pipe
SUSPENSION
OTHER STUFF
cusco roll cage
carbon fiber mirror
front carbon Lip
and alot
Thanks for the shout out's Saad. I really appreciate the feedback! It was great to work with you, and make sure you keep this post updated so I can keep track of your build after I depart from MAP.
Cheers,
Adam
Cheers,
Adam
