Evo 6 TME 2.1L build...bring on 10,000rpm...
Thought I’d start a thread showing what I’m up to with my new build.
I have a Evo 6 Tommi Makinen Edition which I’ve owned for about 7 years now and have gone through various set ups in that time.
Initially the car was standard apart from an Apexi Power FC which had a crap tune on it when I purchased the car. I got the car tuned and it made 273hp at the wheels on 20psi boost. This lasted 3 weeks before bending a rod. From there the car turned into a big black hole for money!
Initial build was a 2.3L stroker with GT3540R and made 450whp on pump gas and 556whp on C16. This build looked completely factory with factory inlet and exhaust manifolds and factory airbox! This was fairly epic for 6 years ago.
Then I changed a few things and went to a tubular manifold, GT4094R, NOS, AMS inlet manifold, Sparktech CDI and made 736whp on C16 at 40psi.
http://www.youtube.com/watch?v=Alzti06CRUI
http://www.youtube.com/watch?v=EafAm...0&feature=plcp
Now I’m building a new 2.1L destroker motor by myself and changing to a GT4202R…this should be interesting!
Progress will be slow but I’ll try and update this as I go. Full spec of the car as it stands now will follow.
My favourite pic of the car:
Full current spec:
Engine
2.4L Factory Crank
Oliver Billet Rods
JE Stroker Pistons
ACL Race Bearings
Balance Shafts removed
Factory oil pump & water pump
HKS Headgasket
ARP mains and head studs
+1mm JAM valves
Factory guides
JAM Heavy duty valve springs and Titanium retainers
Kelford 272 cams
Adjustable cam gears
3mm Lash Adjusters/lifters
Turbo/Exhaust
BR Tubular Twinscroll Manifold with twin Tial wastegates
GT4094R Twin scroll
Custom dump pipe and exhaust
Turbosmart 4 port boost control solenoid
Intake
Tial BOV
Hybrid Intercooler with custom pipes
Custom 4" intake with K&N pod filter
AMS Inlet Manifold
75mm Throttle Body
Fuel System
1x in tank walbro pump and 2x external walbro pumps - no surge tank
3/8 fuel lines
Bosch fuel filter
AMS fuel rail
ID2000 injectors
SARD Type RJ fuel regulator
Nitrous Express NOS kit running single dry nozzle before throttle body. 75hp jet.
Cooling System
Factory Water Pump
Modified Honda Civic Alloy Radiator
Slim line fan mounted in front of radiator
Drive Train
Self rebuilt gearbox with 4.00 final drive
Evo 4 RS rear LSD and axles
Rebuilt transfer case by Ralliart with factory LSD
Exedy Triple Plate clutch
Engine Management
Link G4 Extreme
Link G4 Knock Box
Suspension/Wheels
BC Red Coilovers
Factory Enkei Tommi Makenin Edition 17" wheels with Hoosier Drag Radials
Enkei Tarmac 18" x 8.5 for road use.
Engine
2.4L Factory Crank
Oliver Billet Rods
JE Stroker Pistons
ACL Race Bearings
HKS Headgasket
+1mm JAM valves
Factory guides
Kelford 272 cams
Turbo/Exhaust
GT4094R Twin scroll
Intake
Tial BOV
AMS Inlet Manifold
75mm Throttle Body
Fuel System
3/8 fuel lines
Bosch fuel filter
AMS fuel rail
ID2000 injectors
Cooling System
Factory Water Pump
Drive Train
Engine Management
Link G4 Extreme
Link G4 Knock Box
Suspension/Wheels
BC Red Coilovers
I'm totally not trying to sound like a dick, but a 2.1 uses a stock 88mm crank. It says on your build sheet that your using an OEM 2.4 crank.
I can't wait to see results. It's going to be awesome. I love the TME's.
New 2.1 spec list:
2L K1 Lightweight Crank
162mm Manley Turbo Tuff Rods
Wiseco 1400HD 87MM Pistons 9:1CR
ACL Race Bearings
Race Balance Shafts with counterweight removed
Factory oil pump & water pump with AWD Motorsports water pump adapter plate
AWD Motorsports 87mm Headgasket
O-ringed block
Cosworth H11 Headstuds
ARP mains studs
AMS CNC Head with +1mm valves, beehive springs, titanium retainers, bronze guides
Kiggly HLA Regulator
HKS Cam Gears
Things left to decide on - please help!
1) Cams - I'm thinking Kelford TX280 (280, 276 combo) the same as what AMS are running but am unsure. The GSC S3 cams also look good. What are peoples opinions here?
2) Does the oil pump need modifying/high flowing? If so, how do I go about doing that?? I'm planning on smoothing the oil grooves in the block and rounding corners where possible.
3) Oil clearances - I'm thinking of aiming for close to 0.003" for the rev's I'm aiming for but am not totally set on that yet. I don't have the funds to try this and fail so opinions needed here too please?!
4) Head stud torque - I'm thinking close to 100ftlb on the H11 studs but haven't as yet done any research on this. Any suggestions?
ACL Race Bearings
O-ringed block
ARP mains studs
HKS Cam Gears
Some more parts pics
AWD Motorsports head gasket - factory 4G63 overcut to 87mm
87mm Ring Compressor
EGT quad band thermocouple kit
HKS Cam belt
Kiggly HLA, AWD Motorsport water pump adapter, AMS Clutch fork stop, Stainless allen key bolt rocker cover set
New front pulley bolt
Cosworth H11 Head studs
Fluidamper Harmonic Balancer
HKS Cam Gears
HKS Cam belt
HKS Cam Gears
