My typical overkill build... :) shooting for 1000+ hp
#33
#34
It is an Air/water setup. Are you referring to the heat ex-changer in the front of the car where a front mount typically is or the Air/water core where the fuse box normally is?
#35
Here's my setup - https://www.evolutionm.net/forums/ev...m-exhaust.html
#38
If you push this engine and get exhaust temps up there, which it looks like u will, it will most likely burn through.
#40
Seriously, "normal" is relative to where you live or where the car came from. Obviously states that see tons of salt in the winter due to heave snow are rough on cars.
#41
Looking good so far. Man thats a lot going on the a factory fuel hanger. In regards to the downpipe. Ive built a few aluminum downpipes on LS based motors and not seen any problems. Just needs to be good quality. All those cars made 800+whp thru a 3 inh dp. So i think with the it flowing better you will be ok.
#43
quick update. I finished the Air/water setup. Renewing the tags monday and going for it's street tune next week. I don't think anyone could be as excited as I am for next week to get here.
#44
Can you provide more information regarding the battery setup? It looks like it's been professionally assembled. Did you buy this piece or put it together yourself? I ask because I have experience in aviation/mil-spec wiring. It looks fantastic.
More information on the battery as well!
-Acree
-Acree
-Acree
#45
Sorry Acree, I missed it the first time somehow. I bought all the parts and made it myself. Most of it from ebay. lol. It is just standard interlocking relay harness I modified with nut rivets to attach it to the plate I mounted to the battery box with a car audio breaker terminals and etc..
