Mad Cow
Old Feb 24, 2013 | 12:36 PM
fjm9898's Avatar
Mad Cow is on her way south for her make over.
Old Feb 25, 2013 | 05:14 AM
AngryEvo8's Avatar
^Home pickup ftw! That's service right there. Good luck on the rest of your build.
Old Feb 25, 2013 | 07:03 AM
JTEVO2932's Avatar
Yeah thats awesome!!
Old Feb 28, 2013 | 05:11 PM
fjm9898's Avatar
Goal Build is as follows:
ER built 2.4LR:
- ER Wiseco 1400HD 9:1 pistons
- R&R 156mm I beam connecting rods
- ACL bearings
- ARP L19 Head studs
- ARP rod and main bolts
- New OE oil pump with balance shaft delete
- Factory gaskets and seals
- OE 100mm crankshaft
- Gates Blue Timing belt
- New OE Water pump
- Oil pan with windage tray
Head Build:
- ER street port
- GSC R2 Cams
- GSC springs and retainers
- GSC +1mm valves
- New Valve stem seals and cam seals
- HKS Cam Gears
- Kiggly HLA
Other added mods/work:
- New PTE 750hp FMIC
- All new fluids in everything
- Upgrade to Exedy triple plate
- Upgrade the RCs to FIC 1050SP injectors
Car will be staying on pump gas for road racing track days and street use. E85 might come but it will be a while until I go that route.
Once all this work is done i will be getting the last few CF bits to finish my Rexpeed style replica and getting a few bits painted/re-cleared.
Old May 2, 2013 | 02:19 PM
fjm9898's Avatar
Update on a few more goodies.
Head is being machined for +1mm GSC valves as well.
Clutch was upgraded to a triple plate.
Not going tubular manifold right now, over budget.
Supplies for track season
Mad Cow on the lift at English Racing getting the engine dropped in. Should be running by end of day today. Dyno tune scheduled for next weekend.
Old May 16, 2013 | 12:20 PM
fjm9898's Avatar
Mad Cow is done (for now).
She made 480Awhp on 92 pump. My goal was 525+ but i know why she is down on power. When i first saw it i was upset that $15k of work only netted me 50hp, but i quickly got over that. For starters, she is only on 22psi right now. She was previously making 430AWHP on 27#s. As you can see in the graph it made 440AWHP on 20#s. So slightly more power on 7psi less boost is pretty nice.
So why arent we running the 27psi we were before? Well the Crap pile of a manifold is severely choking the engine with back pressure. The car was running into knock and just couldnt take anymore boost. I plan on eventually getting a manifold for the car and getting it re-tuned in the future, but right now i am going to step back and enjoy the car before i go tossing another $2000 at it. maybe this winter when English does their yearly Dyno weekend closer to me, i might go for the new manifold and open her up. Right now i am just going to call it a 480AWHP break in tune.
92 pump gas should be good for 28-29psi of boost, car gained about 20hp per lb of boost between the 20psi and 22psi run @ 440hp to 480hp. being conservative on saying it would average 15hp per lb of boost from 20 up to 28#s puts the car at 560AWHP. if i am lucky and it holds 20hp per psi up to 28, that puts the car at 620awhp. Only time will tell what it actually can do.
Old May 31, 2013 | 08:47 PM
fjm9898's Avatar
Wash, clear turn signal, cf hood installed
Old Jun 9, 2013 | 09:33 AM
fjm9898's Avatar
Canards on
Diffuser on
Old Jun 30, 2013 | 11:23 AM
fjm9898's Avatar
Showing the Car at Forum Fest. My Car on Vendors row next to the NW3S 1000hp 3000GT
Old Feb 21, 2014 | 07:45 AM
fjm9898's Avatar
Was winter time so i jumped in an started to work on some things.
Got a Cyber Evo Ed Front (replica) for track days. I am going to make my own canards that match the Cyber Evo ones. The standard voltex canards just dont seem very aero efficient.
Also made some brackets to help hold the under tray in the correct place and transfer down force into the frame rails. I need to make 2 more for the middle still.
Old Feb 21, 2014 | 07:52 AM
fjm9898's Avatar
Also got started on the engine bay clean up. Alot of hack work done under there over the years by previous owners. While working i popped a hole in the AC condenser, well BECAUSE RACECAR, i guess i will remove it.
Also i knew the last owner and i knew he blew a Rad hose and it blew coolant everywhere, After a year of daily driving it after he blew the coolant hose the thickness of the dirt in the engine bay was horrendous because of the sticky coolant. I spent a few hours wiping things down to the point were i can actually see white paint again.
Wiring was ridiculous. I am going to have alot to sort through. Pulled the meth kit wiring out and a few other random wires that lead to no where.
Old Feb 25, 2014 | 02:00 PM
fjm9898's Avatar
Made a Custom Breaker bracket for the trunk mounted Battery.
Got a few things Powder coated.
Worked on my Custom Oil Cooler setup
Stealth Zetronix instal.
Drilled and tapped the IM for the IAC sensor, the EM for EGT and the Tstat housing for water temp.
Welded up the old IAC hole in the IC piping as well as the old meth nozzle hole.
Old Feb 26, 2014 | 11:20 AM
LatinImagexx's Avatar
Looking good man. Definitely get some videos of the mad cow on the track
Old Feb 27, 2014 | 09:37 AM
fjm9898's Avatar
Thanks man. Alot of work left to do.
I didnt like the Fiberglass mounts my Vmount wing came with so i Fabbed up some of my own.
Then Chamfered the edges and countersunk all the holes.
There were a few things i didnt like on the wing so i fixed those too. It came with a hardware kit that was all Cap screws and way to long. Basically the least aero dynamic bits they could of supplied. I got all new hardware and counter sunk what i could.
Their bolt vs the counter sunk ones i used. Only thing visible is the nut. (yes threads fully engage the nylon locknut)
Old Mar 3, 2014 | 09:32 AM
fjm9898's Avatar
Bunch of things back from PC, Wrinkle black. Going to do another batch next winter in the flake blue again. The VC, Turbo compressor housing, New Radiator brackets, the WG hat and the BOV hat. Ran out of time/funds for this winters upgrade session, so those will have to wait for next winter for their PC.
Got a Fluid Damper for the 2.4LR
Got my first set of Sparcos on. Pass side to come in the spring.
Got it all back together this weekend. Spent a good 20 hours. Cleaned up more wiring, Engine bay dress up and new wheel well liners as well.
On its shake down drive to get gas and back. Still rocking the winter wheels.
Quick Reply: Mad Cow
