doncarbone's '03 OZ Rally -> '06 Ralliart engine swap
#31
looks promising. your committment will pay out when it is all finished. do the evo 7 look but keep it silver. my buddy has an older ralliart turbo and he keeps up with a stock evo 8 on the highway. get that swap completed and throw some boost in there.
#32
i don't think im going to keep it silver...not that i don't like it, but when i throw a body kit on the car obviously the kit will be unpainted; and in an attempt to save money (and still achieve a sick look for the car), I was thinking of going with a full 3M 1080 matte black body wrap; no need, therefore, to spend money on painting the kit and detailing the OEM parts
example: thoughts?
#34
will turbo at some point; that's the next step, but probably won't happen for a while. want to do an engine rebuild; forged pistons, rods, camshaft, ported/polished head stage etc... will be beast, but an expensive undertaking.
example: thoughts?
example: thoughts?
To each his own!
#35
example: thoughts?
example: thoughts?
Example::
(also following the GTR theme :P)
#36
Pretty big update this evening on sourcing parts:
purchased my wheels and tires; I was going to go with the Volk TE37V's at 17x7.5 (45mm offset, 6mm inset) with the fancy 4x114.3 bolt config; but after talking to three dealers it looks like at the minimum I could have expected a 4-5 month wait time!! not going to bother; i'd have them on my car 1 or 2 months before it'd snow lol
anyway; i still wanted lightweight and after further thought decided a 16" wheel might deal better if i lower the car quite a bit. finally decided with 16" Enkei RPF1's on Bridgestone Potenza RE760 Sports.
i'm sure everyone and their grandma has heard of these but here's a pic:
tonight i also ordered the Tein Basic Coilovers, front camber/alignment kit and the Wilwood Big Brake kit (red calipers).
flywheel still hasn't arrived...it should tomorrow though; at which point I'll get a bunch more pictures of the install on here
#37
SPAL 12" high performance radiator fans ordered today.
flywheel arrived from CM; it fits so the motor and tranny will be in the car by the weekend - many pics to come soon
#38
tranny and motor connected. looks like the upper right hand motor mount from the 4G94 won't fit; have checked with lordco (local outfit) to see if they can source one quick from their local warehouse.
ran into a minor snag too with the P/S return hose from reservoir not fitting; as well as the high pressure hose for P/S.
not sure if any ralliart guys could help confirm this; but does the high pressure outlet from the P/S pump face the firewall?? we are using the 4G94 P/S pump that's where we're running into a few of these problems with hoses not fitting, but i think the pump is ok, it's just we need the diff hoses.
pics:
Motor dropped in with tranny. All mounts fit except passenger upper mount:
tranny finally bolted up after the new flywheel arrived from clutchmasters (they sent me the wrong one by mistake before which was meant for a 2008 Lancer GTS:
pic of the shifter assembly in place; bolted perfectly to where the auto gear changer used to be; will definitely replace the shift knob at some point lol
EVO VIII steering wheel
neither the radiator or the headers are bolted in place yet; was trying to identify how much room we have for radiator fans; looks like we're good; might do one 12" for overheating and a 10" for the A/C
another pic showing clearance
clutch pedal in place; was a huge job cutting a hole through the firewall to get that thing to mount perfectly. brake pedal obviously will be changed lol to the 5spd
was a bit hard to snap a pic, but this is where we had to cut through the firewall to bolt the clutch pedal assembly
P/S pump; need to know if the Ralliart pump faces the firewall like this one does
return hose from reservoir will need to be sourced as the 4G94 one isn't even close to fitting correctly
4G94 upper right motor mount; bolt orientation needs to be opposite where the middle bolt is on the right and the two top/bot bolts need to be left
pics:
#39
Looking to source that side motor mount...on this diagram looks like part #6 is the right one; "side mount bracket":
tho does anyone know if there's another part needed alongside the bracket?
you can see from the 4G94 side mount that its basically the same deal just the bolt holes are the opposite config
#40
#41
you can see here the 3 bolt holes on the bracket that will fit the 4G69 (#6)
the picture i took is of my old side motor mount from the 4G94 that does not fit (u can see the bolt config is the opposite of the white diagram)
#42
#43
used parts sourced, installed this weekend:
passenger side upper motor mount
5spd brake pedal
brake pedal switch (for taillights)
p/s high pressure hose
p/s return hose from reservoir
i've updated my first post with a list of interior parts and have separated my aftermarket listings by category
should i keep the prices i paid on there?
5spd brake pedal
#44
5spd brake pedal
5spd brake pedal
What mounts are you using?? Plan on getting a Blox roller stopper?
Also keep moving forward, summer is on it's way and you'll absolutely love the sound of the intake past 5500 rpms...
If I were you, I couldn't sleep at night, good job!
#45
blox roller stopper not sure, i heard it adds a ton of noise??
fairly extensive custom work done to bolt the clutch pedal assembly in place through the firewall; has to be an exact/flush fit or-else it won't work. is difficult to cut that hole through thick steel (seems the steel there is doubled up too for some reason from the rest of the firewall lol). was particularly difficult as the space was limited to do this. i can't say how things would have went if my OZ rally was the manual 5spd version; might have bolted right up.
- the one motor mount, passenger side top (bolt orientation is opposite to - that of the oz rally u need the 4G69 top mount, otherwise it bolts up)
- p/s high pressure hose is totally different as is return hose, but they will fit the oz rally p/s pump and will reach the reservoir too
all the 4G69 parts i listed in my first post u will need but they will fit without problems once u can get ur hands on them.
only custom job was getting that clutch pedal in but that's just because i was doing an auto to manual conversion
i can't wait man. this project is all i think about these days it has turned into an obsession i think.
