Buschur 2.3L BB FP Black Build Thoughts
Hey all,
So I have been putting together a build list and wanted to get people's opinions about it and thoughts about what they might change.
2006 Lancer Evolution IX MR SE
Current supporting mods to go along with the planned build:
Precision 1200 cc injectors
Aeromotive FPR
AMS Fuel Rail
Buschur Double Pumper
AMS FMIC
AWD ported stock turbo manifold
Invidia Test Pipe
Megan Ported o2 Housing
Fujita UICP and Intake
Injen LICP
Megan DP
HKS CF-Ti Exhaust
Hallman Pro MBC
EGR Block off Plate
Drivetrain
Evo VIII 5spd conversion
Exedy Twin HD
AMS Stainless Steel Clutch Line
AMS Front Motor Mount
Planned Buschur 2.3L Build:
Buschur 2.3L
Buschur Stage 3 Head
Buschur TB
Buschur Intake Manifold
Complete Upper and Lower Gasket Kit
ID 2000 Injectors
ARP L19 Studs
BB FP Black Ported
Tomei Pro 270 Cams
Tial Q 50mm BOV
Spooling Up COP
Cam Sensor Shield
Jegs Catch Can
Mitsu Oil Pump
Mitsu Water Pump
STM Oil Cooler Kit
Timing Belt
Koyo Radiator
E85/93Pump
Fortune Auto Coilovers
Touge Factory Limited Edition Enkei NT03+M's
Dunlop Direzza II's
Aeromotive FPR
AMS Fuel Rail
AMS FMIC
Invidia Test Pipe
Injen LICP
Megan DP
HKS CF-Ti Exhaust
Hallman Pro MBC
EGR Block off Plate
Drivetrain
Exedy Twin HD
Buschur 2.3L
Buschur TB
ID 2000 Injectors
ARP L19 Studs
BB FP Black Ported
Tomei Pro 270 Cams
Tial Q 50mm BOV
Spooling Up COP
Cam Sensor Shield
Jegs Catch Can
Mitsu Oil Pump
Mitsu Water Pump
STM Oil Cooler Kit
Timing Belt
Koyo Radiator
E85/93Pump
Dunlop Direzza II's
Dirch the br intake. Even br tells you its pointless and drops lowend torque... Or go with the rev3 by map if you must.
Also a cheap *** weapon r catch can is just as good at a jegs high dollar
Also an evo 8 water pump is 1/3 the price and works just as well. Its short the alt braket bolt hole which is the only diff. But the intake still bolts to it... Worked for the 8s and every 4g63 before so why not ours.
If you dont plan to delete the balance shafts make sure to get a kelvar bshaft belt.
Right now the invoice on the build is $15k so paying for the Jegs can isn't going to bother me really
I got quoted $170 for the IX water pump, what does the VIII go for?
Balance shaft was gone in the first build I did and I have a Fluidamper, The balance shaft is eliminated in the Buschur 2.3L also.
If I get tired of it or want more I'm just going to pull the trigger and pick up a GTR but I'm giving the Evo another round of fun for the time being
I have to double check on the injectors, they might, just might be 1600's and not 1200's... I forget for sure
You made a nice list that will add up quickly. Only things that I see that you may want to reconsider is from what I understand you do not need a fuel rail unless its for looks, the stock is good for sub 700ish HP. Also take a look at ETS intercooler and piping kit. I just got mine in the mail and its flawless, you can look at it in my build thread at the bottom of my post.
As for cams, I cannot speak on the tomi, but I just picked up a set of GSC R2 which are for strokers and look to be very promising. Call english racing if you want to know more or look on the forums about them.
I have always been loyal to certain vendors because of customer service and results they have provided. This forum offers many great vendors and tuners, MAPerformance, English Racing, Bushur, Spec Ops to name a few.
If you like Bushur, I know they offer tons of services that you could maybe get a better deal on such as all porting work if you also buy the short block from them. I also recomend looking through the forums for the HP level you are looking to reach and use their formula which is proven with certain part combo's.
Good luck with your build, once you pull the trigger, you wont regret it!
Hey all,
Aeromotive FPR
AMS Fuel Rail
AMS FMIC
Invidia Test Pipe
Injen LICP
Megan DP
HKS CF-Ti Exhaust
Hallman Pro MBC
EGR Block off Plate
Drivetrain
Exedy Twin HD
Buschur 2.3L
Buschur TB
ARP L19 Studs
BB FP Black Ported
Tomei Pro 270 Cams
Tial Q 50mm BOV
Spooling Up COP
Cam Sensor Shield
Jegs Catch Can
Mitsu Oil Pump
Mitsu Water Pump
STM Oil Cooler Kit
Timing Belt
Koyo Radiator
Speed Density dual map tune E85/93Pump
I think that I have a pretty solid grasp on the right parts for this build but would like to hear what everyone thinks, thanks in advance.
Aeromotive FPR
AMS Fuel Rail
AMS FMIC
Invidia Test Pipe
Injen LICP
Megan DP
HKS CF-Ti Exhaust
Hallman Pro MBC
EGR Block off Plate
Drivetrain
Exedy Twin HD
Buschur 2.3L
Buschur TB
ARP L19 Studs
BB FP Black Ported
Tomei Pro 270 Cams
Tial Q 50mm BOV
Spooling Up COP
Cam Sensor Shield
Jegs Catch Can
Mitsu Oil Pump
Mitsu Water Pump
STM Oil Cooler Kit
Timing Belt
Koyo Radiator
Honestly, if you aren't going to go bigger than the fp green, I would use the $15k-20k as a downpayment on a GTR and sell your evo for another big piece of it. The Evo will be faster with the same turbo, but not $15k worth of faster.
Interesting I haven't heard that about the BR ported intake mani. Whats the difference between that one and the Rev3?
Get the 9 pump, the 8 and 9 water pump have a slight difference to the where the 9 has a different mounting point on them or some bs
![Thumbs Down](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsdown.gif)
Other than that, your setup looks pretty good man. Looking forward to seeing a build/dyno thread in the future!
I stay loyal to a few companies as well who have proven track records. AWD Motorsports who is local to me has done all of my work since I have owned the car and I have been real happy with them and they are doing this build for me.
They have always potined me in the right direction and have a really good relationship with Dave@Buschur so I know I will be getting a good deal.
I just paid off the Evo this past month and was heavily debating selling it and putting the cash down I am going to be spending on the GTR but decided to go one more round with the Evo since I now own it outright.
A lot of people dont take into consideration when getting into a GTR the fact that if you grenade the trans its $15k+... The brakes are $15k to replace, etc, etc... Same goes for people trying to get into Evos, they simply dont take into consideration the maintenance aspect.
So, that being said this build will be quite a bit more power than I had with my 2.0 and HTA Green. If I get bored of it I will sell the Evo and get the GTR.
Its going to be somewhere around 600+ if I want to push the turbo. I'm going to push it to see the peak numbers and then probably dial it back a bit so I dont grenade another motor.
I saw an oem pump for cheaper than that I can't remember the site though :/
Get the 9 pump, the 8 and 9 water pump have a slight difference to the where the 9 has a different mounting point on them or some bs![Thumbs Down](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsdown.gif)
I will have a build thread which will include pics, dyno video, dyno sheets, etc just as I have with the other build I did
