Hatchback Mirage (CL2A) Full EVO IX Conversion, A5 3.0 V6 Tdi Quattro engine
My first ever blog & one for this build.
http://evo-audi-colt.blogspot.ie/
Auction Picture
Hi
Have my CL2A about 4 years now.
Was 1.5 automatic
Then rwd Mivec bolted to an evo vi gearbox
Now i have been going all out over past year.
Finally created a photobucket account so will have pics of the progress to keep you all interested.
So far my car has evo Vi running gear throughout.
Audi A5 rear diff .
Red stuff pads all round on new disc's & braided hose's, Internal hydraulic handbrake & Evo IX Master Cylinder.
Clutch master cyclinder swapped for Evo IX part.
Audi A5 Tdi Flyby wire throttle fitted inside the car.
Complete front end stripped.
Genuine Evo IX front panel
Genuine Evo Ix Front bumper & Splitter.
Genuine Evo IX Alloy Bonnet.
Genuine Evo IX Front wing's
Genuine Evo IX Arch Guards.
Door's reskinned with Evo IX front & rear Door skins.
Doors need to be converted to electric window & central locking.
Door cards replaced with Evo IX Part.
Quarter panels reskinned with EvoIX rear door & complete quarter panel.
Rear panel & lights cut out & Evo IX rear panel replaced with
Genuine Evo IX Lights & Boot & Evo viii rear bumper for now
Boot will be either a fibreglass or carbon skin because shape is heavily different
& will be using bronze polycarbonate glass to shape new rear
Complete Dash swap From Evo IX & Centre console.
Bride low max seats & hopefully a nardi deep corn wheel.
Auction Picture
Hi
Was 1.5 automatic
Audi A5 rear diff .
Hi
Project is still full steam ahead, Although im in college now so funds have slowed down
I still plan on fitting the A5 v6 engine, i now have ecu, loom, Engine, gearbox, Dual plate clutch.
Still need to get a dual mass flywheel, as you cant get single mass for the dual mass now & also a manual a5 rear diff.
I have one but its automatic, i only use it for fitting up & templates.
This year i have ordered or sourced a Cusco Evo IX Power Brace, Cusco 6 Point Dashdodger Rollcage.
Evo Ix Disc's Drilled & grooved all round. Ebc Red stuff pads allround.
Nrg Evo Ix Wheel Boss kit (very hard & expensive to get hold of)
New window regulator with motors both sides.
Still waiting on an order from mitsubishi, with all the relevant bumper fitting brackets so everything fits up 100%
Going to be ordering a New Evo IX rear bumper during the summer easily €500
Then ive choosen to use Gaz Gold coilovers but cant order them until the car gets weight with full drivetrain in,
So i can pick the right spring rates.
I also got my hands of a genuine set of evo IX wheels to keep everything authentic, Was stooked to get these in such good condition aswell.
Also a special unit thats takes the audi gateway canbus signals & converts them to analogue outputs so i can still use
the genuine evo clocks for speedo & rev & also engine light, as i will be fitting the audi wheel sensors, g sensor & wheel angle sensor
along with the bosch 8.0 system for abs & esp.
This can be disabled at anytime also.
I already got a set of Fx-r hid's for my Evo Ix headlight so i plan on making quad projector evo lights with red cut-off shields so the projector looks red during sunlight.
Ill post pics of the new items soon.
So to answer your question yes, I plan on getting huge progress on this build over the next few months.
A5 Quattro 6 speed gearbox
Here is my last colt
http://juiceboxforyou.com/2013/02/evil-twin/
I built it to see what the car would be like with an evo engine & short wheelbase etc.
The reason for Diesel engine after this build, Was economy/ Power/ Noise & weight distribution
The Evo engines, Gearbox & transfer box all sit forward of the front axle. leaving alot of overhang weight. Hence understeer.
The A5 engine alone weights the same as the evo engine & gearbox.
But sits only slightly forward of the axle & the gearbox weight is all behind the axle.
So this leaves a better weight split, Plus in a car only weighing between 1280-1350kg & geared high
Leaves engine rev's at 1500rpm at 120km/h & when worked out should return anywere between 40-50mpg.
The car will be running a hybrid gtb2265 turbo & just one silencer & pass NCT/SVA all day long even after it's mapped.
for hopefully 280-320hp 500-550ft-lbs
And finally the noise
Bet you werent expecting that from a diesel
Just updated my blog with some electronic elements that are required for this build.
Above the normal ecu & loom swapping & changing that is.
evo-audi-colt.blogspot.com
Another update to the blog with relevent information about why i choose
this new drivetrain.
Audi A5 Quattro gearbox,
First & only gearbox that has the front diff mounted this far forward.
Meaning that the engine sit's just in front of the axle as the axle centre line will be 1" behind the axle.
All other quattro box's would have meant the engine sat to far forward and that would mean this conversion
would not be possible as the front evo ix support panel is already mounted 4" further back.
Got some work done on the skyline project im also working on, Ordered a ralliart gearknob in black for the colt aswell this week,
Also my chipquick arrived meaning i can de-immobilise my audi ecu once i remove the chip.
:/ easier said then done
Updated the blog with some pics of the subframes fabrication
Joeekrub
Jun 25, 2017 01:24 PM
Joeekrub
Jun 20, 2017 03:04 PM
FS[SouthEast]: Super Lightweight - Super Custom- One piece quarter panels
Joeekrub
Motor Sports Parts
16
Aug 24, 2016 02:08 PM
FS[SouthEast]: One piece door/quarter panels - ultimate weight savings
Joeekrub
Jun 24, 2015 05:49 PM
FS[SouthEast]: FS: Evo 9 Rolling shell. Clean title. 40k miles
Joeekrub
For Sale - Cars For Sale
Apr 18, 2015 05:12 PM
