pturnerIV's 6266 powered 2.0L evo X
What up everyone! My name is Page, I am 20 years old and live in Utah! Thanks for checking out my build! Feel free to leave any suggestions/feedback you want! Always open for new ideas!
Bought my evo on June 25, 2013.
It had already had a CNT catback exhaust and a COBB SF intake
I guess my window tint was a little too dark to see the temp tags!
After several months of research and studying I finally came to the conclusion of what I wanted to do/build!
Then after another week I changed my mind once again!
So I am happy to finally say we are underway! All parts have been ordered and I will be dropping my car off on Friday to start getting torn apart! Here is what I have planned!
Motor:
Block: NewOEM short block w/ Darton MID sleeves
Pistons: CP Pistons
Rods: MAP X-beam rods
Rod bearings: ACL Race Series
Crankshaft: New OEM unit, stock stroke
Main bearings: ACL Race Series
Main bolts: ARP
Oil: Shell Rotella T6 5W-40
Cylinder head: Ported OEM unit
Valves: Ferrea Super Alloy +1mm
Springs: Kelford
Retainers: Kelford
Camshafts: AMS TMP Cams
Head studs: ARP
Head gasket: OEM
Valve cover: Powder coated-???
Induction, Injection, Ignition (and Exhaust):
Turbo kit: ETS Dual wastegate V-Band Kit
Turbo: Precision Turbo 6266 CEA Ball Bearing
Wastegate lines:
Wastegate solenoid: Grimmspeed 3-port EBCS
Intake: ETS 4" Intake
Air metering:
MAP sensor:
Intercooler piping: ETS 2.5" piping custom powder coated- ????
Intercooler: ETS 3.5"
Radiator: Mishimoto X-Line w/ cooling pipes
BOV:
Catalytic Converter: Speedcircuit Cat-Delete Test Pipe
Catback: CNT Dual Exhaust
Injectors: Injector Dynamics 1300cc
Fuel rail: Boomba Billet
FPR: Tomei type "L"
Lines: Custom Braided Steel lines
In tank pump: Radium Engineering Surge Tank w/ dual 340lph pumps
Ignition coils:
Spark plugs:
Drivetrain:
Transmission: Cobb's upgraded Transmission
Transmission fluid:
Shifter bushings:
Gate selector bushing:
Clutch: Competition Clutch 6-puck, sprung
Clutch master cylinder: Map CMC evo VII/IX upgrade
Flywheel: ACT Streetlite
Transfer case: Cobb's upgraded unit
Transfer case fluid:
Rear diff: Stock OEM
Rear diff fluid:
Extras:
-IKT evoXpods tripple pod A-pillar
-AEM AFR/Boost Failsafe gauge
-AEM Oil Pressure 150PSI gauge
-Innovate Motorsports EGT gauge
-Megan 2" Lowering Springs
-Cobb Accessport V3
Special thanks to Ziptie Dynowerks in Salt Lake area for helping me with my build and tuning out my car! Also have to give a huge thanks to UT_evoX for helping me out with every dumb little question I had along the way and also for stealing his build platform!
******Build is not done yet and things left blank are either unknown to me at this time or yet undecided.
Motor:
Pistons: CP Pistons
Main bolts: ARP
Springs: Kelford
Retainers: Kelford
Head studs: ARP
Head gasket: OEM
Wastegate lines:
Air metering:
MAP sensor:
BOV:
FPR: Tomei type "L"
Ignition coils:
Spark plugs:
Drivetrain:
Transmission fluid:
Shifter bushings:
Rear diff fluid:
Extras:
-Cobb Accessport V3
First mod ever: New brakes, tires, and rotors!
Hawk quiet slots & HPS pads- NOT RECOMENDED
MAPerformance evo IX CMC upgrade:
IKT Custom tripple gauge A-pillar pod:
SpeedCicuit Heatshield:
SpeedCiruit Test Pipe: (Might have to sell)
The Competition:
Brother-Inlaw's 2008 STI
Father's BUILT 1967 Camaro RSS/SS
My CBR600rr:
Mother's Jeep Grand Cherokee SRT8:
My CBR600rr:
