razorlab's simple build(s)
Old Apr 12, 2021, 11:45 AM
  #1606
RazorLab's Avatar
Received 1,056 Likes on 764 Posts
Originally Posted by EVO196
Looks Spotless for being under a cover for that long where are you moving too?
Isn't that the point of a car cover?
Moving upstate to Poughkeepsie NY.
Old Apr 29, 2021, 11:45 AM
  #1607
Crzykdd's Avatar
Hopefully the garage is insulated!
Old May 9, 2021, 12:30 PM
  #1608
RazorLab's Avatar
Getting closer to having this car running again!
Got the downpipe on finally. Started to swap fresh fuel pumps in. Started with my Radium surge tank. Pulled my F90000274 to replace it with a F90000295:
Then I went to clean out my surge tank and realized it was filled with weird black shavings...
What I ended up seeing was the anodizing on the inside of surge tank had failed... Yikes! Good thing I pulled the pump to swap or I would have run the car with all these shavings in the surge tank!
Old May 9, 2021, 05:55 PM
  #1609
Pal215's Avatar
Great catch! Who makes this surge tank? They should know better than to use materials that flake off with the use of E85 or Gasoline.
Old May 9, 2021, 07:00 PM
  #1610
LetsGetThisDone's Avatar
Received 1,570 Likes on 1,347 Posts
It's a radium. Thats interesting. I would contact radium before putting that together. It's just going to keep flaking and the bare aluminum will corrode and gunk up filters.
Old May 9, 2021, 07:04 PM
  #1611
RazorLab's Avatar
Yea, I'm for sure not going to re-install it. I emailed them, we'll see what they say. I'm sure it's way out of warranty. I've used the tank since 2015.
It's also odd that it's just at the lower level. The surge tank was full when I took it out, so the part where it's flaking was not at the ethanol line. Wonder if it's from the worm clamps?
Old May 9, 2021, 07:06 PM
  #1612
I initially though it was at the level of the pump and maybe the pump is bouncing around in there. But I doubt that bracket it's hung on is bending/flexing around.
Old May 9, 2021, 07:23 PM
  #1613
RazorLab's Avatar
It's not from anything contacting it, the anodizing is bubbling up. The bracket ain't moving. It's L shaped and super rigid.
Here is before I started wiping it down and it before a bunch came off on my rag, you can see the anodizing bubbling up:
Old May 10, 2021, 06:45 AM
  #1614
RazorLab's Avatar
Argh, Radium is out of stock at least 2-3 weeks out.
Now to hunt to see if any vendors have the 20-0059-00 FST Surge Tank in stock...
Old May 10, 2021, 07:25 AM
  #1615
Roccy's Avatar
that was a good catch, never seen that before.
Old May 10, 2021, 07:30 AM
  #1616
RazorLab's Avatar
Found a vendor. Hope to have a replacement by the weekend...
Old May 10, 2021, 12:41 PM
  #1617
Ayoustin's Avatar
I like Radium stuff, but that's exactly what happens with poorly prepped anodize jobs. Good catch.
Old May 10, 2021, 12:54 PM
  #1618
Biggiesacks's Avatar
It could have been real bad if all that had clogged up the sock. Thanks for sharing, I have a radium fuel filter I'll be keeping a close eye on from now on. What kind of fuel was sitting in there? Any additives/stabilizers etc in it?
Old May 10, 2021, 02:13 PM
  #1619
RazorLab's Avatar
Straight E80 that has been sitting in there for almost a year and a half.
The surge tank itself is six years old.
Old May 10, 2021, 05:14 PM
  #1620
deylag's Avatar
You could get the old part re-anodized. I can buy it and the modify the surge tank to double containment with a teflon tank. Let me know if you are interested in selling it.
Quick Reply: razorlab's simple build(s)
