razorlab's simple build(s)
#1622
Received the new surge tank today. I also took this opportunity to upgrade to Radiums new fuel pump hanger.
I currently have their old design hanger, but their new design is so much better and also way easier to install. In fact, after looking at the surge tank next to the new hanger, I wonder if a surge tank is even needed anymore for most people? At least now I will have zero possibility of pump starvation...
#1623
That is SOOO much better than their previous design (which I have installed). The old design had those floppy check-***** and the bottom overall wasn't sealed very well at all. This new unit is completely sealed with a different one-way bottom inlet. I think you are right, this new design looks like it makes a surge tank NOT required even with slicks....
#1624
Well, not all is smooth in new fuel pump hanger land.
Looks like the Walbro 255 (new style GS352) is just shy of fitting correctly in the new hanger. I have both the fuel pump outlet and the radium fitting butted up against each other and the pump sits a little too tall for the canister. Which makes the fuel sock push up against the check valve at the bottom of the canister, causing it not to operate correctly...
You can see what I mean in this video I shot:
#1625
While you shouldn't have to..... can you cut the top barb off the fuel pump outlet or shorten the radium fitting to get the clearance you need? Kinda like the Walbro 450 install onto the stock hanger.
#1626
Radium responded and actually told me this is normal and won't stop the valve from working but I have a very hard time believing that as it's basically smashed up against the sock currently.
#1628
I'm with you, I wouldn't leave it that way either. Do you think an OEM style sock might help? ~$9 from rockauto.
#1629
SMH.... It's like no matter how much you spend there is always something. Guess that's just part of the game. Good luck getting it sorted out.
#1631
Alrighty. I filed down the radium fitting. I couldn't also file down the pump nipple as there is some internal stuff I didn't want to mess with.
This gave me a little more room, however, the sock still pushes up against the check valve, just not as bad as before. I'm just going to install it and cross my fingers.
#1632
Nice, that should be good for some peace of mind.
#1633
Removed the old Radium fuel pump hanger and lookie what is all over the sock of the pump? lol. Those damn surge tank anodizing chips.
Good news is the old radium fuel pump hanger is in good shape with no failing anodizing like the surge tank had.
The new radium pump hanger was 1,000% easier to install.
#1634
Made a ton of progress today. Engine bay looks like a complete engine bay again.
I just have to attach the turbo drain line to the block, swap in fresh oil, and get some fresh E85 and I'll be starting it up for the first time since November 2019.
I'll put the manifold heat shielding back on after I go through some heat cycles and check all the bolts.
EVO196 (May 17, 2021)
