razorlab's simple build(s)
Old Aug 30, 2021, 10:58 AM
  #1711
fireroasted's Avatar
Originally Posted by EVO8LTW
Nice. Who makes that low-rise 4 post?
That is an Advantage Lifts unit. pretty beefy. It does go full height and I put a car under it. With 3 inches to spare on the ceiling. It has a hydrolic jack between the rails to lift the car off of the rails.
https://www.advantagelifts.com/
Old Aug 30, 2021, 11:12 AM
  #1712
mar387's Avatar
Originally Posted by razorlab
Here is the first lift I did with the quickjacks. They are really smooth and easy to operate.
http://www.youtube.com/watch?v=4pq3y9qWu8c
I also recently installed some hanging cabinets above my tool chests and also bought two tall cabinets. It's so nice to move stuff out of plastic bins!
One of the cleanest Evo 10s I've seen. Wish you the best in NY!
Old Aug 31, 2021, 07:17 AM
  #1713
Jaraxle's Avatar
Razorlab,
What is your power level now? Are you concerned at all that the half shafts or rear diff cannot hold the level of power your car is producing? I think you mentioned the ACD being overwhelmed, but it wasn't an issue.
Old Aug 31, 2021, 08:48 AM
  #1714
RazorLab's Avatar
Received 1,056 Likes on 764 Posts
Originally Posted by Jaraxle
Razorlab,
I haven't optimized my tune for the new head, cams and turbo so no idea. Soon, once I get it back together after I complete the new fueling upgrades.
With the OEM port head, Kelford cams and 5858, the car made 640whp DJ on the street at 29psi and low 500's on track at 24-25psi. With my street map, the car was basically making 400wtq. I purposely keep the torque "lower" to preserve my HDSS clutch.
I don't see 400wtq hurting anything.
deylag (Aug 31, 2021)
Old Sep 6, 2021, 10:41 AM
  #1715
RazorLab's Avatar
Got all the fuel upgrades done and took the Evo out to fine tune.
Changes:
- OEM fuel rail changed to Radium Fuel rail with fuel damper
- OEM fuel feed line with small inline filter changed to -8AN line with Radium SS fuel filter
- OEM return line change to -6AN and using OEM feed hardline.
- FIC 2150cc injectors
These upgrades completely smoothed out my fuel pressure at WOT, before it was jaggedy and would also drop pressure past 7500 rpm. Now it's flat and smooth.
Before:
After:
Old Sep 6, 2021, 01:41 PM
  #1716
Jaraxle's Avatar
I am betting that fuel filter upgrade was 85%+ of smoothing out the fuel issue. But it's just a guess. That torque curve is RIDICULOUSLY flat !!!
Old Sep 6, 2021, 03:02 PM
  #1717
RazorLab's Avatar
When I pulled the Evo out of the garage today the sun was hitting it just right so I had to snap a photo...
The following 7 users liked this post by RazorLab:
codgi (Sep 9, 2021), Crzykdd (Sep 7, 2021), EVO196 (Sep 8, 2021), Jaraxle (Sep 6, 2021), mikemike396 (Sep 11, 2021), RobbieOh (Sep 6, 2021), shinyrat (Nov 2, 2021) and 2 others liked this post. (Show less...)
Old Sep 6, 2021, 07:54 PM
  #1718
RobbieOh's Avatar
Looks real nice!
Old Sep 7, 2021, 01:02 PM
  #1719
Lumpy Sticks's Avatar
Does that thing ever stop making power? Looks like you could spin it to 9k no problem.
Old Sep 8, 2021, 08:31 AM
  #1720
LetsGetThisDone's Avatar
Received 1,570 Likes on 1,347 Posts
If he had a real clutch, it could easily make over 500wtq on the hit and carry it pretty far as well.
Old Sep 8, 2021, 08:35 AM
  #1721
RazorLab's Avatar
Indeed, if I had a more stout clutch, I would run the turbo at 32-34 psi and let er' rip.
Maybe one of those new ACT twin discs is in my future.
Old Sep 8, 2021, 10:07 AM
  #1722
Crzykdd's Avatar
BTW picture with the phone or something else...? Curious as to what your shooting with these days (when you want to take really good photos)/
Old Sep 8, 2021, 10:24 AM
  #1723
RazorLab's Avatar
It's from my iPhone 10. I have an iPhone 12 Pro Max for my job which has a much better camera but it's so large I never have it in my pocket.
Old Sep 8, 2021, 01:23 PM
  #1724
An extra 100wtq would be fun! Especially if it stays going up top.
Old Sep 11, 2021, 02:30 PM
  #1725
RazorLab's Avatar
So this 5558 GEN2 continues to need a ton more WGDC for the same amount of boost versus the 5858 GEN1
I have it basically maxed out WGDC up top and it won't make 30psi. I'm using almost 40% more WGDC up top and it's making less boost than the 5858 GEN 1 did. I guess time for me to do a boost leak test.
5558 GEN2:
5858 GEN 1:
Quick Reply: razorlab's simple build(s)
