razorlab's simple build(s)
Old Oct 11, 2021, 02:08 PM
  #1741
LetsGetThisDone's Avatar
Received 1,571 Likes on 1,348 Posts
I think the cat is most of whats hurting you. English Racing has data that the Gen2 5558 makes more power than the CEA (gen1 compressor) 5858.
Also, every MD is different. The car could very well be making 600whp+ on a dynojet. And then cat could be hurting you for ~10% power at that level.
And then VD data isn't always perfectly comparable to a real dyno.
Old Oct 11, 2021, 02:57 PM
  #1742
RazorLab's Avatar
Received 1,056 Likes on 764 Posts
Yes, I know every dyno is different, that is what I also mentioned the car feels soft compared to before. It is for sure making less power than it did with the previous setup.
I might just pick up a cheap $150 test pipe and see what happens. I'm actually surprised the cat is making a difference since it is rated for up to 850hp.
Old Oct 11, 2021, 04:18 PM
  #1743
850hp out of a high strung 2.0L is much different than 850hp from something larger and not working as hard. I also wouldnt be surprised if a ~600-650whp Evo is 800 crank hp.
Old Oct 11, 2021, 04:38 PM
  #1744
Jaraxle's Avatar
I didn't notice a hit with that GESI CAT, but I am only at 450whp. It IS rated for 850, but honestly it IS also a restriction of some sort compared to a HOLE.
Has was your AFR curve, and wasn't the E85 the crap from the NY ? Maybe it is something else....
Old Oct 11, 2021, 04:40 PM
  #1745
RazorLab's Avatar
Looks like a 2020 Supra does around 310whp on this dyno, so about a normal reading Mustang dyno.
No way am I believing a 600whp Evo has 200hp drivetrain loss. Sorry. With that logic, I was making 800hp before on a 5858. Come on, that's 25%. lmao. None of that computes with the hundreds of evos I have tuned over the years.
Old Oct 11, 2021, 04:42 PM
  #1746
RazorLab's Avatar
E67 according to my sensor. This was with adding timing to match what I was using before on E79 in California. It put down 503 first pull from the street. 512 whp after putting back in a degree.
Old Oct 11, 2021, 04:45 PM
  #1747
Lumpy Sticks's Avatar
I would agree seeing that they typically do 330-340whp on a DJ.
Old Oct 11, 2021, 05:36 PM
  #1748
CurseDSM's Avatar
650 would be around 845,850 crank if were still using the 30% drivetrain loss but yes I agree with your statement. Everything isn't working as hard at that point.
Old Nov 2, 2021, 06:51 AM
  #1749
shinyrat's Avatar
Bryan,
I just finished catching up on this thread, and apologies for hijacking, but are you still interested in selling?
I've tried reaching out via PM, but I don't know if you've received my messages.
Old Nov 2, 2021, 06:52 AM
  #1750
shinyrat's Avatar
Also, I was curious as to why so many of the images are missing from previous posts?
Old Apr 14, 2022, 01:51 PM
  #1751
RazorLab's Avatar
Sold the Evo today. End of an era. For the first time in over 30 years, I no longer own a Mitsubishi.
Old Apr 14, 2022, 05:08 PM
  #1752
Jaraxle's Avatar
This is a sad day.
Old Apr 15, 2022, 07:18 AM
  #1753
V.8MR's Avatar
Howd you make out in terms of price?
Old Apr 15, 2022, 08:36 AM
  #1754
Monster4's Avatar
Sad to hear. I am sure the new owner is thrilled, they got a gem.
Old Apr 15, 2022, 01:04 PM
  #1755
Biggiesacks's Avatar
Quick Reply: razorlab's simple build(s)
