BULLY_EVO_IX - The Blue Bull
EB IX GSR SSL- The Blue Bull - MAP EF3, S2, Full Race
I figured I would start a build journal here. I purchased my first EVO earlier in the year. I wanted a IX GSR. Took many months of searching for a stock or stockish one.
Here is how I got her. 71K miles EVO IX GSR SSL in EB. Completely unmolested with a Mint interior. Beautiful shifting transmission. Car consumes zero oil. It only had a turbo back exhaust and a brand new Exedy Clutch with ACT Steet flywheel installed from Ivey Tune.
pics next to my other car (wrx)
One more of the suby for good measure
I quickly started to modify the car. The first things I added were:
Megan Downpipe - Catless
ETS Intake
Buschur Ported and Coated OEM manifold
MUSE UICP - stock location battery
MUSE LICP
Walboro Fuel Pump
MAP O2 housing -recirculating
ETS wide tank FMIC
New bank #1 O2 sensor
Gates Belts
OEM evo IX BPV
The Gold Packaging Tune up Kit - all that stuff
New Brakes
Stainless Steel Lines
17x9 TRM C3 Wheels
Prosport Boost and OIL pressure Steering Column Mount
Grimmspeed EBCS
New stereo
UK Rear Badge
So I hit the DYNO at PSI Proformance In Lansdale PA www.psiproformance.com (Steve is the man FYI)
I made 344 AWP
Dyno Sheet:
The Numbers were OK, the car was quick but it left a lot to be desired.
Soooo I started buying more parts, I started with some Fortune Auto 500's because I was getting tired at looking at the 4x4 wheel gap:
The car is currently in the shop. Some new goodies are being installed.
Note that's some coolant drip, stock pistons were in excellent shape.
Latest Mod List:
Megan Catless Downpipe - the fitment is perfect for ACD!
Turbo XS Cat Back
ETS SPEED DENSITY INTAKE
Full Race Pro-Stock Manifold
MAP EF3 JB Turbo with Ported Exhaust Housing with 3" Anti-surge inlet
GSC S2 Cams
Kiggly Racing Beehive Valve Springs + Ti Retainers
Supertech Valve Seals
4-Layer Cometic Metal head gasket
MAP HD H11 head studs
EGR Blockoff
MUSE UICP - short route with tial flange - DEI wrapped
Tital Q VTA (I also have the QR piece)
MUSE LICP
MUSE O2 EWG Dump
Walboro 255lph Fuel Pump
PTE 1000cc Injectors
AEM Fuel Rail
Spoolin-UP COP Kit
ETS wide tank FMIC
Phenolic Intake Manifold Gasket
New Plugs OEM
All Gates Belts
Stainless Steel Brake Lines
17x9 TRM C3 Wheels
AMS remote oil pressure sending unit
Grimmspeed EBCS
Exedy Cluch
ACT Flywheel
Boomba Front Engine Mount
AMS Radiator Hoses
Shift Linkage Bushings
Whiteline adjustable RSB
Whiteline Bump Steer Kit
MOOG Endlinks on all 4
Fortune Auto 500 coils
ETS Mini battery kit
Its still not all put together otherwise I would have final engine shots. I'm going speed density finally! woohoo.
I'm sure I am forgetting some odds and ends but you get the drift.
Still running the stock IX intake manifold and TB. That will probably be next and a bigger turbo If I don't like my numbers.
Car should be all wrapped up by end of the weekend. My next tuning appointment is Tuesday 11/26 at PSI proformance. Looking for a 93 Pump tune, hoping for over 450whp.
ETS Intake
MUSE LICP
Walboro Fuel Pump
ETS wide tank FMIC
Gates Belts
OEM evo IX BPV
New Brakes
17x9 TRM C3 Wheels
Grimmspeed EBCS
New stereo
UK Rear Badge
I made 344 AWP
Dyno Sheet:
Latest Mod List:
Turbo XS Cat Back
GSC S2 Cams
EGR Blockoff
MUSE LICP
MUSE O2 EWG Dump
AEM Fuel Rail
Spoolin-UP COP Kit
ETS wide tank FMIC
New Plugs OEM
All Gates Belts
17x9 TRM C3 Wheels
Grimmspeed EBCS
Exedy Cluch
ACT Flywheel
AMS Radiator Hoses
FS[Northeast]: Advan RG-D 17x9.5 +25 Gold with tires
SwabeLife
For Sale - Wheels / Tires
Mar 10, 2017 06:16 PM
olo
Apr 12, 2016 04:23 PM
wrx110487
Oct 7, 2015 08:49 AM
2012_Evo_X_GSR
Evo X Dyno Results
16
Oct 4, 2015 02:28 PM
