Mr. Evo IX's 2013 MR Touring Build
Mr. Evo IX's 2013 MR Touring EFR7670 EWG Build
Part 1
AMS Intercooler
Cobb Upper and Lower IC piping
Cobb Inlet and Intake
Tanabe Concept G TBE
Cobb, scratch that Milspec High Flow Cat
Cobb 3-port BCS
Cobb V3 AP
ID 1000 Injectors
Walbro 450
E85 374wtq/356whp 93oct 339/314 ProTuned by Calvin
Eibach Prokit lowering springs
Ichiba 20mm bolt on spacers
Part 2
Borg Warner EFR 7670 EWG
Full Race T4 EWG kit w/Ceramic Coating
Full Race Upper and Lower IC piping
Full Race 3.5" Intake
Full Race Vband Dump Tubes
(2) 38mm Tial Wastegates
Aluminum Valve Cover
Driven Fabrication V3 AN10 Catch Can
Boost Resource Manifold, Turbo, and DP Blankets
AEM Uego Wideband
Part 1 (Cobb Stage 3 + Fuel System)
Showroom Floor 2013 Evo X MR Touring
Stock Exhaust removed
Cobb Hi-Flow cat, this has since been sold and replaced with a Mil-Spec Hi-Flow cat
Tanabe Concept G Resonated exhaust
Cobb AP (Missing NAV knob finally replaced by dealer)
Baseline tune (Stock mapping with aftermarket exhaust compared to Stage 2 OTS mapping)
Parts stacking up in the hallway
Disassembly
Bumper off
Bumper
Test fitting
Cobb 3port BCS
AMS FMIC
AMS FMIC fitting
LICP fitting
LICP fitting
Dirverter valve pipe
BCS plumbed
Upper pipe installed
Inlet and intake pipe installed
Walbro 450
Cobb ID1000 fuel injectors
E85 and pump gas custom mapping by Calvin @ Cobb Plano
Delta
Eibach prokit installed, looks like a hovercraft
How she looks now
Coming soon!!!
AMS Intercooler
Cobb 3-port BCS
Cobb V3 AP
ID 1000 Injectors
Walbro 450
Part 2
AEM Uego Wideband
Disassembly
Bumper off
Bumper
Test fitting
Cobb 3port BCS
AMS FMIC
AMS FMIC fitting
LICP fitting
LICP fitting
BCS plumbed
Walbro 450
Delta
How she looks now
Coming soon!!!
Part 2
The gathering of parts!
EFR 7670
Loosely clocked
What a beautiful Turbo
Safety first
Dismantling Cobb bolt-ons
Strut bar, heat shields, and BOV pipe removed
Soaking in PB Blaster
Friend helping out, thanks for friends!
Most useful tools of the day!
Impact tool makes easy work of easy to reach bolts (posed)
Time to go underneath, on Jackstands
Tray removed
Bumper removed
DP Removed
There were a lot of bolts removed between this photo and the next one including the "***** Bolts" (Upper and Lower Turbine Brackets)
Water lines and oil lines were removed as well
Manifold removed
Turbo almost ready to come out, actually I tried to just pull it out like this.
going in for surgery
I removed the housing in the car then it came out very easily
Empty.. lots of space now
Unwrapped the new manifold.. pretty
Nice welds, nice bolts and washers
Test fitting boost resource heat protection, certainly hides the beauty of what's inside. Function first.
Looks different than some that I've seen online, very tight fit, this may be difficult to get on later.
Cutting gold foil for heat protection
EFR 7670
Loosely clocked
Safety first
Tray removed
Bumper removed
DP Removed
Manifold removed
More gold foil wrapping
Test fitting manifold, scratched it a little, should have gotten some tape.. oops.
Test fitting turbo, center section is going to have to be rotated back
Required
Fitting, this coupler is a little too close to that EWG for my liking
More test fitting
Too be continued, I'm pausing right now to see what Full Race can do about the turbo outlet coupler being so close to the external wastegate, I still need to test fit the
dump tubes as well but I need the car back on jackstands for that.
Dump Tubes and Boost Resource DP heat protection
Dump Tubes from the top
Wastegates plumbed, new upper pipe in photo
Valve cover installed
Driven Fabrication Catchcan
Driven Fabrication Fitting
Charge piping installed
Mr. Evo IX (Mar 10, 2016)
FS[MidWest]: 2013 Mitsubishi Evolution X MR Touring - 38K Miles
Stugotz
For Sale - Cars For Sale
Nov 1, 2017 05:06 PM
FS[SouthEast]: FL 2013 Evo MR Touring White,37K mi Warranty No mods
dsm2nrs
Jul 20, 2017 05:22 PM
FS[Mid-Atlantic]: 2013 WW EVO X MR Touring Under 11k Miles
Astro_Train
Sep 2, 2016 04:06 PM
Vostok 7
Evo X Dyno Results
Jul 28, 2012 12:17 AM
