Evo IX 2.3 Liter Build FP Black Build
#481
https://www.intel.com/content/dam/su...chProdSpec.pdf
I don't know if this is your model compute stick, but it says it needs 5v 4amp and it appears to be a USB-C jack. Page 24.
Quick glance through some forums and most are saying you need at least 3 amps for it to work right.
These seem to have decent reviews. https://www.amazon.com/DROK-Converte...ct_top?ie=UTF8 add a fuse and wire it up to a USB jack and your gold.
#482
Very cool idea! It would certainly free up some space and take away any extra noise associated with my current power supply solution. I'll give it a try and see what happens. It looks like they also have a DC to DC converter with the USB adapters already wired in that provides 3 amps. Benchmark tests have shown that even at full force the compute stick consumes about 14.2 watts, which shows why 3 amps could work.
https://www.amazon.com/GEREE-Waterpr...ct_top?ie=UTF8
#486
Its mounted, it just rotates by hand. It spins freely. Doesnt give me warm and fuzzy feelings...
Emailed radium and this was their response:
It is ok/normal for it to swivel, but it should not leak. Give it a try and let us know if there are any issues.
Technical Support
Radium Engineering LLC
www.radiumauto.com
To receive the latest info on new products, join us at:
Facebook Instagram
Anyway thanx for the reply pal215
Technical Support
www.radiumauto.com
Facebook Instagram
#487
I can see how that can be a little sketchy. I will say this though, when I installed my older oem fpr into my old fuel rail, it did continue to rotate until i put the bolts in. If it rotates super easily then I would be concerned, but if you can feel o-ring friction I would try starting the fuel pump and checking for leaks.
Technical Support
www.radiumauto.com
Facebook Instagram
Technical Support
www.radiumauto.com
Facebook Instagram
#489
Update:
The DC-DC power supply arrived as well as the 4 port USB hub. I couldn't wait to install them.
Soldering USB connector to power supply
4 port low profile USB hub. I used 1 port for the UEGO Wideband, 1 for Tactrix, 1 to power the video converter and ran a usb extension up to the glove box for thumb drives and other external items.
Positioning power supply and USB Hub
Final assembly.
Hell yeah.
The noise was still there and I figured out it was coming from the AEM gauge. The AEM wideband heater circuit is a noisy one! I added a noise filter and it took it all away. The video is still a little noisy, but not enough to justify spending another 50 bucks on a video noise filter.
Edit: I did end up buying a 50 dollar video noise filter and it didn't work (Jokes on me)
Overall I'm very happy with the setup, but I am having a problem with EcuFlash. It defaults to using the RS232 converter for the wideband to read from the ECU instead of my Tactrix cable. Is there anyway to change the default port that ECUflash uses instead up unplugging my wideband each time?
Final assembly.
Hell yeah.
Last edited by Pal215; Jul 3, 2018 at 03:16 PM. Reason: Changed Evoscan to ECUflash
#490
Looking good. You could try manually assigning the Serial adapter com port in Windows hardware manager, you will then need to tell evoscan about the new com port for the wideband.
#492
Oh thats a bit of a different problem. Ecuflash looks for the device hardware not a comm port. If its mistaking your RS232 converter for an openport then there are some underlying issues. I would start by making sure your Ecuflash and openport drivers are both the most current version. Im guessing you aren't using an actual tactrix openport, so if the above doesn't help you may need to actually change to a piece of actual tactrix hardware. You could try hitting up tactrix about the problem too, they got back to me with some tech questions I had a while back.
#493
#494
you might just try a different RS232 converter too, but see what tactrix comes back with before spending money
