Evo Lander my 05
Evo Lander my 05
Hi to all here!
This is my first 4g63t powered car, formerly I was driving different some STI's and WRX's and lancer X
So the specs are:
1. Turbo Evo-9 Ported and polished, with bigger hot side
2. Exhaust manifold - B̶o̶r̶l̶a̶ custom covered with ceramic coating, crocked in bandages DEI
3. Downpipe and oulet - Greddy
4. Exhaust BLITZ Nur Spec R Evo8
5. BOV ̶T̶u̶r̶b̶o̶s̶m̶a̶r̶t̶ ̶d̶u̶a̶l̶p̶o̶r̶t̶ ̶ evo 8 bypass
6. Intercooler kit CX-RACING with intercooler 600x150x75 mm. + Silicone and T-bolt Pipings 2,5 inches
7. Boost controller GREDDY Profec BSpec2
8. Turbo timer BLITZ DT,
9. ECU control unit - EVO 8
10. Harness - EVO 8
11. A mechanical throttle, throttle cable - EVO 8
12. Injectors - RC 800cc
13. Idle Sensor - EVO 8
14. Throttle position sensor - EVO 8
15. CAI - K&N typhone
16. Tuned by Filin motorsport
17. Air/Oil Separator - OBX
18. Fidanza Adjustable Cam Gears - (blue inlet, red - exhaust)
19. Timing Belt Cover - Carbon Creations
20. Kevlar timing belt - Power Enterprise
21. Spark plugs and valve cover - Carbon Creations,
22. All the silicone pipes - SAMCO.
23. Cam shafts - Cosworth 272/272
24. Fuel rail - Perrin Performance
25. Brakes - 4-piston 315mm front, and 2-piston 295mm rear (3000 GT VR4)
26. Front upper strut
27. Gauges - Toser (voltmeter\Oil pressure\Boost\oil temperature)
28. Interior - Recaro (Evo 8).
29. Tuned by - Filin Motorsport
So the specs are:
10. Harness - EVO 8
