FS: Wiseco Forged Pistons
After winning the Evo X Stock Appearing class at this years Buschur Shootout I ended up with a certificate for a set of Wiseco Pistons with up to a $600 retail value. This certificate can be used online or mailed in before 12/31/09 to redeem one set of ANY Wiseco Shelf-stock Automotive Pistons that include Rings, Retainer Clips, and Piston Pins. So that means DSM, EVO basically whatever they have available here:
http://www.wiseco.com/Catalogs/Sport.../MiniMitsu.pdf
Other applications can be found on their website.
$300 for Wiseco Pistons Certificate
So instead of ordering these and being locked into one type of piston, I'm selling the certificate for $300 and I'll send you the coupon code for online redemption as well as mail the certificate at your request. It looks like the only thing you would have to pay for is UPS Ground shipping to claim the pistons and maybe tax if they are in your state.
Worst case scenario I'll just order the standard bore before the certificate expires and put them on my shelf for the future but figured I would see if anyone is about to buy them anyways.
Here are some examples of the kits you can get, most prices I've seen are in the $430 -$500 range for them:
Wiseco Forged Pistons (K636M85): Standard Bore - 4B11 - EVO X
- Stroke: 3.386" (86mm)
- Rod Length: 5.659 (143.75mm)
- Compression Height: 1.309 (33.25mm)
- Head cc's: 49
- Dome Dish: -4.50
- Gasket Thickness: .048" (1.2mm)
- Deck Clearance: 0
- Block Height: 8.661 (220mm)
- Compression Ratio: 9.0:1
- Pin Diameter: .9055" (23mm)
Wiseco Forged Pistons (K595M85): Standard Bore - 4G63 - EVO VIII-IX
- Stroke: 3.465" (88mm)
- Rod Length: 5.905 (150mm)
- Compression Height: 1.378 (35mm)
- Head cc's: 43
- Dome Dish: -14
- Gasket Thickness: .034" (0.86mm)
- Deck Clearance: 0
- Block Height: 9.015: (229mm)
- Pin Diameter: .866" (22mm)
- Gram Weight:
- Std. Bore = 335
- .020 Bore = 340
- Head cc's: 49
- Dome Dish: -4.50
- Deck Clearance: 0
- Head cc's: 43
- Dome Dish: -14
- Deck Clearance: 0
- Gram Weight:
- Std. Bore = 335
- .020 Bore = 340
Ok last call at $300 plus shipping.
Specs & Pics of what they look like here: http://www.streettunedmotorsports.co...vo_pistons.htm
