PPI Vertical fmic, aluminum radiator setup
Most of you had probably seen this setup for sale a week or so ago on here. Well i ended up buying it, purchased saturday, recieved it tuesday (car sold tuesday morning). With no plans of getting into another evo, its going back up for sale. With that being said here it goes!
-custom bell intercooler core with PPI end tanks (previous owner made 750whp)
-custom made aluminum radiator, retains use of one factory mount. 1.5 thick, will fit with just about any turbo!
-3" upper ic pipe (tial flange) along air intake temp bung gor you SD guys, can be plugged very easily!
-includes licp (will work with nearly any t3 setup) might have to change a couple or two depending on your turbo.
-ets straight route upper rad hose
-all t-bolt clamps to make this setup work
-EVERYTGING TO MAKE THIS WORK IS INCLUDED.
YOU WILL NEED A SLIM FAN!
And before the question gets asked, this will not work with your stock A/C condensor, you will need a 92-95 eg civic a/c condensor and custom lines (dont let it scare you, its very simple and very cheap (roughly 100-150 in parts)
Any other questions, i will be happy to answer.
Just keep in mind this setup was for sale last week at $1000!!!
Just so i dont eat too much of a loss, im going to post it at $400 shipped! You will not find this setup anywhere else! This is the shortest route ic setup possible, along with being almost fool proof for any kind of boost leak!
(Prevous owner is obviously mitsubishijoe)
