FS: Sway Bar, Camber Plates, MR Bilsteins
#66
Yes...maybe. They definitely would work, but I'm not sure what size adapters are required for the KW3's. If you would measure the ID of the spring and the OD of the upper strut shaft (just below the threads) that would tell us. The upper strut shaft adapters I have are 12mm and the upper spring perches I have are for a 2.5" ID spring. Different sized upper strut shaft adapters are $6 each from GC and the different spring perches are $15 each from GC.
#68
See above answer.
Honestly I don't know the measurements of any coilovers. So, yes, these will work, but it might require different adapters than what I have on hand.
#70
I picked them up sometime early last year. The've been sitting in the box since then. It's the same thing as currently advertised on GC's website.
I got them from Vivid Racing's ebay site. VR told me they'd fit the stock suspension...not even close, so I never made use of them. Since I plan on getting the Vishnu/Ohlins coilovers (which include plates) I won't ever use them.
