FS: Ohlins Road and Track, GC Camber/Castor Plates, Works Rear Pillow Ball Mounts
I have the following for sale:
Ohlins Road and Track coilovers (used)
1 way adjustable 25 click settings
have 5000 miles on them
Front 2 need a rebuild (ususally $80-100 per shock from Works)
SOLD!
Ground Control Caster/Camber plates (used)
Come with all the necessary hardware
Allow you to control both Caster and Camber
Come with 2.5 inch upper spring perches, you can always buy a buy extras from Ground control if you have a different ID spring ($15 per spring perch from GC)
www.ground-control.com
Also if you want to be cheap, the spring perches can be taken to a local machine shop with a lathe and "reduced" to the appropriate size for cheap. (~$10)
SOLD!
Works Rear Pillow Ball mounts (new)
Comes with all the necessary hardware
Asking $120 shipped
SOLD!
SOLD!
Asking $120 shipped
Sorry weekend got busy and I didn't get the time to upload pics but expect them sometime this week. A lot of family stuff going on (father's day). As for rebuilding them, it can be done by Works.
www.worksevo.com
or Ohlins USA
www.ohlinsusa.com
Cost is about $80 - $110ish per shock. If I don't get enough interest for these shocks for the "cheap" price I'm offering. I'll send the fronts in to get revalved/rebuilt myself and bump up the price significantly. They normally cost more than KW V3s (so that should give you an idea) and are better, IMHO. These shocks, for those that don't know, are some of the best budget shocks you can buy for the EVO.
1. Its a monotube shock with special valving on the compression side that is unheard of in a budget shock. Which means it can be super comfy and very quick reacting on the street and then be set to super hard for the track.
2. The valving is so well designed that the click settings actually make a hugh difference in low speed compression and rebound while high speed remains unchanged (what you want in a good set of coilovers), unlike the cheapo products you see everyone buying in this forum.
3. The shock is very consistent = well balanced car. Which means each setting is almost identical across shocks unlike cheap stuff eg: Tein, Megans, Koni yellows, etc where the same setting on 2 different shock will produce different settings. This can lead to an unbalanced car and handling problems.
4. The shock is very high quality, it can take a lot of punishment and will not fall apart like some of the cheaper stuff is known to.
5. It is very consistent because it is monotube where it will stay same and not over heat unlike twin tube shocks. Whether it is being used for 5 mins or hours of harsh operation.
6. It is stainless steel in construction which means it can take the harsh winter/wet road conditions and salt without any worry of corosion.
There is a reason why Chronohunter has a set of Ohlin's R&Ts on his car. A lot of well known Race teams use Ohlins because of their quality
Thanks for the bump Ookami!
www.worksevo.com
or Ohlins USA
www.ohlinsusa.com
In case people are wondering, the reason for the leaks on the front 2 shocks has been determined. The original owner had used anti-siege on the top of the upper mounts of the shock (a big no no), only on the front 2. The anti-siege seeped down overtime and ruined the seal on the shock. I spoke with an Ohlins engineer and confirmed this.
I bought these shocks used, never put them on my car once. Didn't know they were leaking until the begining of this month because I took the time to take off the upper spring perches, springs and dust boots. In case any of you are wondering you aren't supposed to use anything except a very very light amount of (axle) grease on those parts. That is why the shocks leaked after only 5K miles. The original owner assured me they had been used on the street and a few time on the track.
If I don't get any serious offers by the end of this week, I'll get the front 2 rebuilt/revalved myself.
