FS: Ams Wilwood Rally & Ams Wilwood Lightweight Brake Kits! Fit 15's Save 46 lbs!!!!
SOLD
SOLD
SOLD
SOLD
SOLD
I am changing directions with my car and selling off my small brake kits, possibly the whole car soon. They are in good condition! Good pads/seals/rotors with some surface rust from sitting for a while like any rotors on any car. They are still mounted on the car but wouldnt take me long to take them off and boxed up for you. These kits will save you 46 pounds off your unsprung weight on the car! 37 pounds of that is ROTATING MASS! When you get into the physics of things like initial inertia and rotating mass, it nets you an effect FAR greater then the numbers you read above.
AMS WILWOOD RALLY FRONT BRAKE KIT:
The AMS/Wilwood EVO IV/V/VI/VII/VIII/IX/X is a true brake solution for EVO owners that like to play in the dirt! AMS has teamed up with Wilwood to develop a true rally brake kit suitable to fit behind most popular 15" wheels yet provides all of the stopping power of the stock units. This lightweight brake kit shaves 24 lbs. from your EVO, 20 of which is reduced from the rotating mass! Less weight (sprung & rotational) means quicker acceleration, less parts breakage, and quicker suspension response.
Our rally brake kit utilizes robust Wilwood 4 piston calipers and Wilwood B compound pads made for severe-duty asphalt and dirt track use. The vented vane rotor is 11.75” in diameter (stock is 12.75”) and features a lightweight aluminum hat. We supply the rotor and hat pre-assembled with safety wire and include plastic coated braided stainless steel brake lines to protect against abrasion from gravel and debris. Grade 8 hardware and zinc plated caliper brackets complete the package. Race proven on the 2008 AWD class winning AMS sponsored Pikes Peak EVO VIII driven by Dave and Allison Kern!
Features
24lbs. of weight savings, 20lbs. of which is reduced from rotating mass!
Aluminum hat rotors come assembled, pre-torqued and safety wired
Stainless steel zinc plated caliper bracket
Heavy-duty Grade 8 hardware
Plastic coated braided stainless steel brake lines
Will fit behind most 15 inch wheels (some may require spacers)
Direct bolt-on, no modifications needed
Kit Includes
Wilwood Forged Superlight 4 piston brake calipers
Two vented vain rotors with aluminum hats
B compound brake pads
Stainless steel zinc plated caliper brackets
Replacement plastic coated stainless steel brake lines
Specifications
11.75” diameter, 1.25” thick 2 piece fully vented rotors
4.9 cubic inches of pad volume
Complete weight of 20lbs. per side
Known to fit with 15x7 Compomotive TH3 +38mm offset wheels
Known to fit with Team Dynamics ProRally1 wheels 15x7 +40 offset wheels
[B]This kit new is $1650. It has all the stopping power of the stock brembos and can fit 15" wheels. The rotors are thicker then a drag brake kit so you dont lose as much weight but you also dont lose valuable stopping power!!
AMS WILWOOD LIGHTWEIGHT REAR BRAKE KIT:
The AMS/Wilwood Lightweight Rear Brake Kit was designed for the Drag racer or Autocrosser looking for that extra edge. AMS has teamed up with Wilwood to provide this lightweight yet streetable kit that shaves 22 lbs from your EVO, 17 of which is reduced from the rotating mass! Less weight (sprung & rotational) means quicker acceleration and less parts breakage.
Our kit uses a Wilwood forged 2 piston caliper, 11.5” solid cross drilled rotor (stock is 11.75”) and features a lightweight aluminum hat. We supply the rotor and hat pre-assembled with safety wire and include Goodridge braided stainless steel brake lines. Grade 8 hardware and aluminum caliper brackets complete the package. This kit is designed to fit with 15” rims with the appropriate wheel spacers. Because removal of the parking brake is required, this kit is NOT suggested for street use. NOTE: I used the kit just fine on the street, when you park, leave it in first gear and you're fine.
This is the same kit we developed and use on our World Record Holding, 1130awhp EVO VIII which has hauled us down from over 170mph drag passes!
Features
22 lbs. of weight savings, 17 of which is reduced from rotating mass!
Comes with everything needed for install
Kit Includes
Wilwood forged 2-piston calipers
Wilwood brake pads – BP-10 medium friction “Smart Pad”
Aluminum caliper adapter brackets
Grade 8 hardware
11.5” solid cross drilled rotors & aluminum hats (assembled & safety wired)
Goodridge S.S. braided high performance brake lines & fittings
Specifications
Willwood forged superlight 4 piston caliper
Grade 8 hardware
11.50" diameter, solid crossdrilled rotors
Fits 15" rims (no spacers need on any rims i have put on them!)
D.O.T Complaint and T.U.V Approved brake lines
6061 Aluminum machined brackets
Rear calipers are high temp painted green. I can spray them over with black if you would like.
The rear kit is $1,195 new.
Both kits new $2845! Asking $1400 for both kits as a package
Fronts ONLY $1000
Rears ONLY $550
paypal and shipping not included.
SOLD
SOLD
SOLD
SOLD
Features
Kit Includes
Specifications
Features
Kit Includes
Grade 8 hardware
Specifications
Grade 8 hardware
Fronts ONLY $1000
Rears ONLY $550
