For Sale - Suspension / Brakes / Handling Includes pads, rotors, springs, shocks, swaybars, and other handling related components.
F/S: custom adjustable carbon fiber splitter with mounting hardware & turnbuckles
Old Mar 25, 2014 | 09:37 AM
EGbeater's Avatar
Price: $450 shipped in the 48 U.S. states
Parts location: Longmont, CO 80501
*** SPLITTER IS SOLD ***
This is the splitter I used on my car for the latter half of 2013 when I ran my Evo in NASA TT1 (the class formerly known as TTU). It is designed to be as light as possible while also being stiff enough to be effective.
When I built this, no one was making a bolt-on splitter solution for an Evo 8/9, not anything with enough splitter surface for serious downforce and built to the limits of SCCA SM and NASA rules anyway, so I decided to do it myself.
The mounting brackets, hardware, adjustable support turnbuckles, air dam, and shape of the splitter are all my DIY creations; the construction of the CF splitter itself, I got help from Brooks Motorsport Composites (hence the decals).
The splitter blade is shaped to extend 6" from the leading edge of the bumper cover, making it legal for SCCA Street Modified (SM) class autocross as well as NASA TT track racing. Overall dimensions are 71" x 28 3/8". The thickness of the CF splitter is 4mm. All together, with all mounting hardware, it weighs about 14 pounds.
You can see how I arrived at this design here... there were several previous iterations of the splitter done in plywood to save on cost. There's also detailed pictures of the mounting hardware, the air dams, etc.:
https://www.evolutionm.net/forums/ev...o-8-9-a-3.html
As you can imagine, there is a ton of time and effort invested in this setup. The majority of the cost is of course in the carbon fiber cloth and UV-resistant epoxy required for making the splitter itself.
Overall the splitter is in very good shape. It has scraped the track surface a couple times on the outside edges, so I will cover those areas with thin (1mm) plates of stainless steel to increase the durability of the splitter for you... adds a little weight, but better than burning through the CF material unnecessarily.
The ABS plastic air dam is configured to match the Cwest bumper cover on my car, so you will need to adjust the brackets or drill a few new mounting holes to make the splitter match the contours of a Evo 8 or Evo 9 bumper cover. But otherwise, the splitter will bolt up to your car with minimal fuss—the four mounting brackets I made utilize existing mounting points on the front of the car.
NOTE: This part was designed for racing use. The splitter extends too far forward to be able to drive around town and get in and out parking lots with it attached. It is unlikely to survive more than a week of street driving, even if you set at the highest setting and are extremely careful about where you go. But if you buy it, it's your choice what you choose to do with it of course.
Old Mar 28, 2014 | 03:05 PM
kaj's Avatar
kaj
aaaaaw! i've been following this build. if i had my wing already, i'd be ALL OVER this.
once mounting points have been setup, how long does it take to install/remove?
Old Mar 28, 2014 | 03:12 PM
EGbeater's Avatar
About 5 minutes, including jacking up the car. It's just attached by 4 10mm-head bolts and three support rods (no tools required to un-fasten the support rods).
Old Mar 28, 2014 | 03:15 PM
kaj's Avatar
kaj
that would be perfect. then i gotta find a way to fit it in the car to get it to the track LOL.
Old Mar 29, 2014 | 06:34 PM
EGbeater's Avatar
Splitter is sold.
Gruppe-S
Evo 'For Sale' Suspension / Brakes / Handling
26
Apr 1, 2014 03:02 PM
EGbeater
Feb 13, 2014 08:12 AM
EGbeater
Feb 23, 2013 10:55 AM
EGbeater
10
Mar 28, 2011 12:50 PM
EGbeater
For Sale - Wheels / Tires
Dec 8, 2009 07:30 AM
Quick Reply: F/S: custom adjustable carbon fiber splitter with mounting hardware & turnbuckles
