WTB[Northeast]: 1 Evo 8/9 MR Bilstein rear strut (1 of mine is lower than the other. Different part?)
WTB: 1 Evo 8/9 MR Bilstein rear strut (1 of mine is lower than the other. Different part?)
It's similar but the bottom isn't rounded and when I bought it new from Bilstein it came with square edges near the bolt hole at bottom not rounded like my old ones and now the ride height is wrong. It does fit though?
You are definitely correct about that
I'm am trying to track down the part number for OEM Evo 8/9 MR Bilstein rear struts.
Sounds easy but after no luck on google I called Bilstein directly. They do not own the rights nor store any information on the OEM MR Bilstein strut set that they sub out to Mitsubishi. So they don't know the part number nor do they sell those struts to consumers. They only sell a similar but different HD Bilstein strut to consumers. The ride height on the HD strut is lower by 1/4"-1/2" compared to the OEM Evo 8/9 MR Bilstein rear strut I need. Also after calling Swift Springs because that is what I have in there, they confirmed they are different struts and recommend the Swift Spec-R springs to be applied on the OEM Evo 8/9 MR strut because that is what they were engineered for. Also, I like the higher ride because my tire rubs on that one lower side now. Only way to find the OEM Evo 8/9 MR Bilstein strut is on the internet (which I haven't found) OR obtain an Evo 8/9 MR VIN Number for the stupid stealership that can only search through VIN Numbers or a known part number. I don't have an MR, I have a GSR with MR struts swapped in so my VIN won't work.
Long story short, Anyone on here know the OEM Evo 8/9 MR Bilstein rear strut part number, want to give me their VIN number, or want to call the stealership with their VIN number and obtain the part number for me?
Sorry for the novel but I figured some of you Mitsu gods would appreciate the back story. You learn something new everyday.
C.Reed
12
Feb 11, 2014 07:54 AM
mitsuorder
Jul 16, 2013 11:13 AM
Butt Dyno
Dec 30, 2012 03:11 PM
trinydex
Feb 9, 2010 06:05 PM
