F/S: TTP Engineering Alky/Methanol/Water Injection Kit
Old Jun 26, 2006, 11:38 AM
flabarm's Avatar
I'm Selling a like new Alky kit for the Evo. I bought this kit from another member on here a couple of months ago intending on installing. Due to certain financial situations, I've scrapped the plan for alky. I have never even installed the kit. It was on the other members car for 1 week before he was also forced to sell. I would like to get SOLD Also Willing to trade for a 10.5 hotside, arp headstuds plus cash, cam gears
Info from www.TTP-Engineering.com
Get a complete kit that is tested and proven on the shop Evo MR to 405+whp & 445.1tq!
Compatible with methanol!
This kit includes the following:
* High pressure 150 psi diaphragm pump with viton valves.
* Easy install Injector nozzle - pre-assembled!
* 8ft (standard) or 20ft (trunk option) High Pressure Blue Nylon 11 tubing
* 30amp automotive relay
* 4 to 15 psi boost switch, variable injection module, or rpm pill for activation
* Instant On fittings for Pump, Solenoid, and Misting Nozzle.
* Industrial grade electric block-off solenoid - prevents water/alky in lines from being drawn in while not in boost unlike the competitions kits.
* 10ft (standard) or 20ft (trunk) - 10 guage copper wire, for pump
* 20ft of 18 guage copper wire - for other electrical
* Various crimp terminals for wire hookups
* Fuse assembly
* Easy to follow instructions
Requires simple tools for installation -
* 1/8NPT tap and drill
* crimp, cut and strip wire tool
* teflon tape or pipe dope
* adjustable wrench
* flat blade screwdriver
* Reservoir. Or tap into existing windshield washer tank.
If doing an under hood pump install, utilizing the existing washer fluid reservoir makes installation simplified. The advantage of a trunk mounted pump/res install is cooler fluid temps. The 1 or 2 quart containers that come with some competitor models are far too small. Our observation is a minimum of 1-2 gallons for our own driving with 500hp.
Some other kits do not provide a water solenoid. As a result, water/alcohol from the bottle can be sucked in to the engine under idle/cruising which is not recommended! A reservoir is not provided since there is no one size fits all. A 1+ gallon container is recommended.
Pics Added Below
flabarm is offline
Old Jun 26, 2006, 11:49 AM
05WhiteEVO8's Avatar
Where in Florida are you?
05WhiteEVO8 is offline
Old Jun 26, 2006, 11:57 AM
flabarm's Avatar
Brevard County/Central Florida
flabarm is offline
Old Jun 26, 2006, 12:06 PM
gaulrich2003's Avatar
Thumbs up
[QUOTE=flabarm]I'm Selling a like new Alky kit for the Evo. I bought this kit from another member on here a couple of months ago intending on installing. Due to certain financial situations, I've scrapped the plan for alky. I have never even installed the kit. It was on the other members car for 1 week before he was also forced to sell. I would like to get $215 shipped
True statement, I sold it to him and there was nothing wrong with the kit.
gaulrich2003 is offline
Old Jun 26, 2006, 12:17 PM
flabarm's Avatar
Thanks Gaulrich
flabarm is offline
Old Jun 27, 2006, 08:54 AM
flabarm's Avatar
Up For more to see
flabarm is offline
Old Jun 27, 2006, 07:38 PM
flabarm's Avatar
TTT
flabarm is offline
Old Jun 28, 2006, 09:19 AM
flabarm's Avatar
Sorry for the crappy picture of all the wiring, I didn't want to unravel (SP?) all of them. Everything is included that you would get from TTP if you bought the kit brand new
flabarm is offline
Old Jun 28, 2006, 05:33 PM
flabarm's Avatar
Bump
flabarm is offline
Old Jun 29, 2006, 01:11 PM
flabarm's Avatar
flabarm is offline
Old Jul 1, 2006, 07:05 AM
flabarm's Avatar
Bump!!!
flabarm is offline
Old Jul 1, 2006, 07:14 AM
IXmr321's Avatar
where in brevard county?
IXmr321 is offline
Old Jul 1, 2006, 07:15 AM
flabarm's Avatar
Melbourne/Palm Bay. Right down the road from you
flabarm is offline
Old Jul 2, 2006, 11:00 AM
DRFTKNGG's Avatar
I'm local. I want it. I have a carbon fiber air box to trade if intrested, but also have cash. let know. 407-719-8712
DRFTKNGG is offline
Old Jul 2, 2006, 11:55 AM
flabarm's Avatar
PM'ed you
flabarm is offline
