Buschur FMIC and SMC alcohol injection kit.
Buschur Delux FMIC asking $500.
The FMIC is designed by David Buschur for the EVO, it is the old school "delux" system from Buschur Racing. It will work with the stock, or aftermarket upper IC pipe, but you would have to ask Buschur if they have any lower IC pipes designed for this system (I was not running stock turbo, so don't have the same lower IC pipe setup). It basicly needs a strait section of pipe with some couplings and clamps to join the stock turbo outlet pipe to the inlet of the intercooler..... very short very strait, so it should not be hard to do on your own if Buschur does not sell them any more.
SMC alcohol injection kit. SOLD!
The SMC alcohol injection kit is a "universal fit" type of system not specific to the 03 EVO, but will work fine in an 03 and let you keep the stock intercooler spray system. This system is adjustable for the boost where the system starts spraying and a seperate adjustment point for the pressure for 100% flow with a linier ramp up in flow between those two points. It has a low level warning light for the tank, a "spray on" light for when the system is activly spraying, and a test button to make sure the system is operational befor droping the hammer on your car.
Thanks,
Keith
Thanks,
Keith
