Weldon DB2015-A Fuel 1000hp Fuel Pump, $550
This is probably the best fuel pump available right now. Its expensive... but its a Weldon.. it can easily handle over 1000hp Turbo or not.. It has a -10 outlet and -12 inlet.. If you are making alot of power this is the ticket to a good dependable fuel system. I bought it brand new for over $700 and used it for half of this race season... Selling for $550...PM Me if interested.
More info:
Maximum HP:
1000 hp @ 14V EFI (500 hp on Methanol)
1050 hp @14V carb (525 hp on Methanol)
GPH/PSI Range:
85-115 GPH / 0-160 PSI
Features:
All billet body pumps are 100% serviceable/repairable
Self Priming
- Pump may be mounted above fuel cell
vertical or horizontal mount
Breakaway coupling prevents pump/motor damage in the event of contamination
All internal wear components are 100% metallic
No plastics or composite materials. Our internal pumping elements are made of high speed tool steel ans bronze. This results in the longest lasting, highest quality, most durable pump available.
Body machined from billet aluminum
For carbureted or injected engines
Provides Consistent Performance with no fall-off in flow
Precise fuel delivery
Blades self-compensating for wear
5.5 lbs
Current Fluids
Weldon Pump offer the widest range of fuel compatibility.
Gasoline - Diesel - Methanol - Ethanol - Nitromethane - All racing fuels
More info:
Maximum HP:
GPH/PSI Range:
Features:
Self Priming
5.5 lbs
Current Fluids
Mellon Racing
EvoX 'For Sale' External Engine / Power
396
Nov 28, 2014 06:42 AM
