AEM Water Injection System, Brand New!
AEM Universal Kit, 1 Gallon Tank #352353 $390...
Here is some info on it: The Water Injection Kit is a safe and economical way to reduce air inlet temperatures to increase boost pressure for more power. Lower air inlet temperatures allow users to advance timing without having to run higher-octane fuel. This is the most complete kit available on the market straight out of the box- no additional parts required.
WATER INJECTION KEY FEATURES:
Universal kit includes everything you need for installation
Progressive, controller-driven 150 PSI pump
One-gallon tank with integral fluid level sensor
Dash light for system status and low fluid warning
Alcohol Compatible (up to 50% in solution with water)
Progressive controller, provides boost-dependent variable flow
Output provided to either decrease timing or boost if the system runs out of fluid or detects an error
Includes three jets to match your power requirement
