PARTOUT! Innovate Wideband w/DB Gauge - Test Pipe - Intake - HKS 280/272 Cams - MORE!
Make offers! No unreasonable offer will be refused!
I have several items here for sale.
SOLD Innovate LC-1 Wideband with Red DB Gauge. Looks like this when lit up.
$75 eBay Test Pipe, custom bung welded in (For Wideband)
$75 Intake Pipe with Couplers
$350 HKS 280/272 cams - Great torque! Gained me 30whp & 25wtq from just throwing these bad boys on! Plus I got a mean lopey idle.
$40 K&N Cone Filter + MAF Adapter - Has some dented up areas from where the filter layed down on some metal brackets. Otherside looks great!
SOLD Buschur Heat Polished Heat Shield - Already cut to fit your Buschur 3065 setups, and still looks good on the stock turbo too! Could use a little polishing, but still looks great!
SOLD! Hallman In-Cabin MBC - Had this mounted right where the little cubby is under the stereo. It will work great for you too. No scratches.
SOLD Autometer Boost Gauge - Carbon fiber layout, 30/30 psi/vac. No scratches. Comes with everything to hook up, and original box.
SOLD! Autometer Steering Column Dual Pod Holder (Comes with OEM factory steering column already attached so you dont have to drill your current one!)
SOLD Autometer SINGLE Steering Column Dual Pod Holder available too.
SOLD! Used Walbro 255lph. Used for 3,000ish miles. Works great, just pulled it out on Tuesday.
