Zeitronix Zt-2, LCD display, 3.5 bar map sensor, EGT probe/harness
I'm really disappointed that I'm going to get rid of this, but I want/need to do some other things with the car.
I have basically a new Zeitronix ZT-2 with the black LCD display, 3.5 bar map sensor, and an egt probe/harness.
I did install the actual ZT-2 box and boost sensor, but never actually hooked up the o2 sensor for the wideband or the LCD display (except to make sure it worked). I have taken apart the lcd because I was going to use just the lcd in a custom dash project, but I decided that I wasn't going to finish it and I didn't really need it. I already have an AEM wideband and boost gauge. In no way can you tell that it had been taken apart. The casing itself has never been used or mounted and still has the protective tape on it. I did hook up the lcd to make sure that it worked prior to uninstalling the ZT-2. The ZT-2/boost gauge had been installed about 2 weeks.
The egt probe does have some bad threads due to a bad tap job, but you might be able to straighten them out with a die set. It was installed, but never actually wired to the zt-2. It seemed to go into my new manifold with an actual bung just fine with some anti seize. The extension harness for it wasn't even ran through the engine bay.
It comes with the cd (never been taken out of the sleeve), install instructions, all cabling, and the zeitronix sticker (everything pictured).
I paid $530 for the set new. I would like $400 shipped, gaypal fees included.
