Fs:stock Misc. Engine Pullies,tentioners,cam Gears,catch Cans,stock Cams...
Cleaned out my garage full of misc. evolution VIII & IX parts..
Various 2004 Evolution VIII Engine parts:
NEW Eagle H-beam Rods (Standard length)
Alternator
Alternator braket
Starter
Stock Ignition Coils and wires
NEW IX coil cover (3 diamonds)
A/C Compressor
A/C Compressor braket
Power steering bracket
Misc Engine Brakets
Greddy catch can
Ralliart catch can
Tial BOV Flange
Oil pump cover
Oil pan with pick up
Oil Pan with pick up and modified AN fitting return line fitting
Dip stick with tube
Stock Evo VIII complete piston and rod assemblies
Stock Evo VIII turbo 9.8 Hot side
Stock Turbo Actuator
Stock O2 sensor
Stock Crank sensor
Stock MLS intake manifold gasket,Exhaust mani gasket,down pipe doughnut, 3"down pipe flange gasket
Cam belt tensioners
Crank Shaft Dampner pully
Water pump pully
Thermostat housing complete w sensor
Stock Radiator hoses
HKS Radiator Racing Cap
Blitz Radiator Racing Cap
Stock MAF sensor (perfect fins)
OEM cooling fan with Thermostat
GHL Slip fit 3" in and out Resonator and Catalytic Converter
Stock Oil and Brake Fluid caps
New in the box..Calico Racing Coated Engine Rod Bearing (Standard)
Samco intake pipe and K&N Filter With MAF sensor
HEAD COMPONENTS:
Brian Crower Valve Springs & Retainers with keepers
Stock Roller Rocker Arms
JAM No Tick Lifters
Stock Camshafts VIII
Stock IX camshafts
Cam angle sensor complete housing
Stock Cam gears
Yellow valve cover..needs paint
stock fuel rail
Shoot me a PM and an offer...
Alternator
Alternator braket
Starter
A/C Compressor
Misc Engine Brakets
Greddy catch can
Ralliart catch can
Tial BOV Flange
Oil pump cover
Dip stick with tube
Stock O2 sensor
Stock Crank sensor
Cam belt tensioners
Water pump pully
HEAD COMPONENTS:
JAM No Tick Lifters
Stock IX camshafts
Stock Cam gears
stock fuel rail
