FS: SX fuel pressure regulator, model 15402.
As topic states I have a SX fuel pressure regulator model 15402, absolutely perfect condition only on the car for about 8 months. A perfect unit when you are upgrading fuel setups.
Information from manufacturer:
Has two (2) -10 AN inlet/outlet ports, one(1) -6 AN return port, and a 1/8 inch NPT gauge port . Maintains stable fuel system pressure between 35-90 PSI for flow rate flexibility up to 180 GPH (1,100 PPH) or over 1000hp. Has a vacuum/boost reference port for a supercharger, turbo, or intake manifold vacuum connection (1:1 rate). Will holds minimum fuel system pressure for 25 PSI for at least 20 minutes after pump shutdown. Cnc machined from aircraft aluminum so it is very light and precision built. The use of fuel resistant fluorosilicone diaphragms not only provide the same high temperature protection that formally only aircraft use for their fuel systems, but also provide extended life over the competition's rubber based compounds. The extra light weight diaphragm assembly provides excellent pulsation dampening, to dampen the pressure spikes caused by fuel pumps and cycling injectors.
Best of all this is rated for use with gasoline and alcohol... so it is E85 SAFE!
95.00 shipped OR BEST OFFER.
![](http://i21.photobucket.com/albums/b299/twkdcd595/for%20sale/PIC_0028.jpg)
