FS: AEM Tru-Boost, Autometer shift gauge, gauge pods
AEM Tru-Boost $180 shipped -----SOLD-----
AutoMeter Digital Pro Shift Gauge (level 3) $100 shipped -----SOLD-----
A-pilar guage pod for 2 52mm gauges $35 shipped -----SOLD-----
Column mount single 52mm gauge pod $25 shipped -----SOLD-----
True-Boost comes with solenoid, harnesses, boost line, & instruction booklet. It has the black face & silver bezel. I dont have the other bezel/face. Works great. Was only removed because I'm running Maft-Pro with boost control & Zeitronix with boost gauge.
AutoMeter shift gauge comes with harness & instruction manual. Works great. I only removed it cause my Turbo Timer has a shift light function.
Got rid of all my standard gauges so the gauge pods ahve to go too. The A-pilar pod is already mounted to my old stock A-pilar cover so you don't have to damage yours. I trimmed it down so that it can't be seen sticking out from under the new cover. Comes with speaker cover installed. When installed there is a slight gap at the to pof the pilar due to it being on top of another pilar. They are all like this, but I figured it should be noted.
Column guage pod comes pre mounted to my stock upper column cover so you don't have to damage yours.
Yes the Tru-Boost is a boost gauge & boost controller in one. I'll check what the max PSI is. I know you can buy an add on sensor that will read/hold up to 50PSI.
It's a simple install. I tapped power & ground at the radio & the tach signal wire into the ECU harness at the glovebox. I didn't use the blue & purple wires. One is for playback on an autometer tach & the other can be used for a trans brake or line lock.
