Ps pump and alternator 150 shipped for both.
A loud screeching noise is a bad bearing, not a bent pulley. You need a pump. Spray lube on the pulley shafts one at a time. Hit the bearings with the lube. When the sound stops, it's that pulley. If you can't stop it, change your water pump. Lmk about the pump, but i'd rather somebody buy both. Good luck.
