Mark this thread as Sold
FS (NC): AMS Race Balance shaft
1 Post
Sold!!!
I have an AMS Race Balance shaft for sale that was pulled from a motor out of a wrecked car. I don't know how many miles are on it, it looks perfect. For those that don't know this is for doing a balance shaft eliminator and still having the oil pump support from the front shaft. I'm told this is often a good idea when using higher tension valve springs with higher lift cams or aftermarket timing belt or both. I'm asking $100 for the shaft.
Josh
Josh
Buschur Stub shaft (Like Mitsu)
AMS Full balance shaft
Sorry to clutter your thread. Free bump for you.
No. You still need to run the serpentine belt. That belt is what runs the water pump, power steering, etc. Read and check out these images for a better understanding:
http://www.4g63turbo.com/tech/eclips...t-removal.html
Again, sorry OP.
Again, sorry OP.
me and the op are buddies i just bought a oil pan form him 2 days ago for my build so he better be cool LOL all i needed to know is if i need to order a new serpintine belt or not for my oem bs kit. SBR ran out of them so i did not get one. mike told me awhile ago the belt is not to important and i could reuse the one i have but need new timing belt of course. i think it was like 66 dollars or something like that new
1 Post
$100 is shipped and paypal'd
You will no longer be need to run the smaller and shorter balance shaft belt that would normally be behind the timing belt. The oil pump is driven off of the timing belt. The "serpentine belt" is the belt that runs your accessories such as power steering, A/C, and Alternator. It is outside the timing cover and can be seen on the left side of your engine while it is installed and running. The timing belt "should" be under the covers on the left side of your engine and the balance shaft belt is behind that but only on the lower portion of the engine where the front case is located. Let me know if you have any more questions. I've torn down 4 engines in the past month and a half and so far I've found two of these shafts installed! Lucky me! Both engines where running fine and came out of wrecked cars.
Josh
Josh
