FS: Clevite 6bolt rod bearings for Eagle Rods that use 6 bolt bearings
![](http://i1223.photobucket.com/albums/dd503/ghostfacekillah84/clevite6boltrodbearings.jpg)
A few rod manufacturers build or have built rods that use 1gDSM 6 bolt rod bearings. I have a set of spares for use with these Evo rods that take the 6 bolt style bearings. They will also fit of course the 1g DSM connecting rods and aftermarket units made for them.
$38 is the cheapest online shipped.
$25 shipped for my set.
I accept paypal
Clevite CB-1120AL(4) Connecting Rod Bearing Set
Originally Posted by Clevite77 Bearings
These Tri-Metal 77 engine bearings combine the strength of a copper-lead alloy layer with steel backing and an electroplated babbitt metal. The steel backing provides strength and durability; the babbitt overlay provides the critical surface characteristics of slipperiness and conformability. This ideal design has properties not even found in many original equipment bearings.
Medium level of eccentricity and high crush
Enlarged chamfers for greater crankshaft fillet clearance
Made without flash plating for better seating
Use with crankshafts that have oversized fillets
Use with engines that run mid-high RPM range
Contact patterns should ideally cover 2/3 to 3/4 of the bearing surface
I accept paypal
I accept paypal
