agp baffled oil catch can
selling a agp baffled oil catch can. one of the best and cleanest mounting ones.
comes with hoses and clamps. in great condition. asking $80 shipped.
retails around $125.
from maperformance site:
http://www.maperformance.com/agp-oil...lator-evo.html
"The 4G63 in the Evolution VIII/IX is a high horsepower turbocharged engine and runs a significant amount of piston-to-wall clearance. The cylinder pressure from the forced air creates more heat in turbocharged applications when compared to non-turbocharged engines, thus Mitsubishi designed a "loose" engine for added safety and longevity purposes. Unfortunately, a byproduct of an engine that allows a lot of blow-by is oil residue makes its way past the PCV system and ends up in the intake manifold, and many other places.
Oil residue in the combustion chamber of an engine is bad news, and can lead to really bad news with respect to how your engine runs. We have been testing a real solution for a while now that will actually separate the oil from the air flowing between the PCV and intake manifold. It sounds easy enough, as many people have tried to adapt simple catch cans and industrial water valves to remove the oil from the air. Those products do work OK but only separate a small amount with respect to how much oil is actually passing through the system. Enter the AGP Oil Accumulator.
Our three chamber oil separator gathers the airborn oil particles through the middle chamber. Oil is separated from the air through the filtering media and drains through a perferated aluminum plate on the bottom side of the middle chamber then accumulating in the bottom chamber. As this oil gets filtered through the middle chamber, clean air is then filtered again and exits through the top chamber. This three chamber system design provides the best protection against unwanted oil making its way to the combustion process.
The bottom of the Oil Accumulator has a threaded -4 ORB bung and a plug to allow the user an easy way to drain the oil.
The Oil Accumulator is completely constructed of aluminum and comes with a standard brushed aluminum finish. To provide some extra 'bling' to your engine bay, we also offer this polished or powdercoated finishes. This fits the Evolution perfectly and comes with hose and hose clamps for an easy installation."
RussellM
MitsubishiParts.net - WA
Jul 20, 2015 04:48 PM
maperformance
EvoX 'For Sale' Miscellaneous
89
Mar 8, 2012 09:34 AM
TKMotorsports
48
Mar 3, 2007 11:19 AM
