FS: AMS/EXEDY PUSH STYLE Twin HD Clutch Kit with PULL STYLE components.
#60
I see that one of your disk is toast...they are 4.0 new and need to be replaced at 3.0 and pressure plate looks a little warped can you put a straight edge on it(it the first plate you measured)I will make you offer if you can prove the pressure plate is good. I can see through the bottom of measure devise and want to make sure it not the pressure plate and maybe your measuring devise is not straight
