FS[MidWest]: T3 turbo kit, ETS 4" FMIC, GSC S3, Map Rev 3, Full blown double pumper, AEM EMS etc!
I sold my Evo as a roller so this is what I have left!
Located in MN!
![](http://i277.photobucket.com/albums/kk65/dustin_rogers/20140710_220457.jpg)
![](http://i277.photobucket.com/albums/kk65/dustin_rogers/20140710_220514.jpg)
![](http://i277.photobucket.com/albums/kk65/dustin_rogers/20140710_220539.jpg)
![](http://i277.photobucket.com/albums/kk65/dustin_rogers/20140710_220650.jpg)
![](http://i277.photobucket.com/albums/kk65/dustin_rogers/20140710_220625.jpg)
![](http://i277.photobucket.com/albums/kk65/dustin_rogers/20140710_220703.jpg)
![](http://i277.photobucket.com/albums/kk65/dustin_rogers/20140617_154008.jpg)
GSC S3 Cams. $415 shipped/paypal'd
Map H11 Head Studs $175 shipped/paypal'd
Wiseco 1400HD 10.5:1 .010 over pistons $530 shipped/paypal'd
Torque Solution mount kit. Drivers side, passenger side, and rear mount. 400 miles $325 shipped/paypal'd
Map Rev 3 intake manifold with Full blown 70mm throttle body, ceramic coating, phenolic spacer, egr block off plate The manifold has a 70mm flange for the 70mm throttle body WELDED onto it. Hence why i listed them together making it easier. To have the manifold made as mine sits is $819 plus throttle body for another $270! SOLD
OMNI 7 bar map sensor. Brand new. $80 shipped/paypal'd
Greddy Titanium cat back with stainless test pipe. Weighs something like 11lbs(without test pipe). 3.25" 6k miles $700 shipped/paypal'd
Buschur racing driveshaft loop. Not sure these are even still being made. BOLTS IN! $250 shipped/paypal'd
Full blown double pumper with 2 255's. 1800 miles. $500 shipped/paypal'd
ETS 4" thick FMIC. 1800 miles. $550
3" short route upper intercooler pipe with speed density bung and turbosmart flange. Will come with couplers. Runs through hole in front on engine fuse box. $250 shipped/paypal'd
Turbosmart Raceport Blow off valve $220 shipped/paypal'd
AEM Series 1 EMS with cable. I can include a laptop I bought to use with it for an additional $50 $475 shipped/paypal'd or $525 with laptop
Custom 4 port catch can setup with black braided lines, fittings, dip stick, and valve cover. Vents block, dipstick, and 2 ports on head. Mounts to fire wall by passenger side strut tower. Will not fit with abs unless you find a spot to mount the can. $425 shipped/paypal'd
AEM digital gauges. 50psi boost, 150 psi oil pressure, wideband with AMS oil sensor relocation kit. Will come with cd player pod. Sell as a set for $450 or separate.
Turbo kit: (1800 miles on all parts except turbo. Turbo has 300 miles)
-Straight line specialties t3 manifold
-3" downpipe for precision turbos
-Dump tube
-Precision 5858 ball bearing ported s cover 3" discharge. Will come with warranty card that has not been filled out. (made 570/483 @ 31psi on this turbo kit on a mustang dyno)
-Turbosmart hypergate 45mm external wastegate
-Feed and drain lines
-4" intake with k&n filter
-Slim fan
SOLD
Mishimoto Evo 7 Radiator with purple samco hoses.
Located in MN!
-Dump tube
-Slim fan
SOLD
Migsubishi
Aug 8, 2015 07:34 AM
devildevil
13
Jun 1, 2014 09:50 PM
devildevil
20
Apr 24, 2014 06:45 PM
devildevil
Apr 7, 2012 10:02 AM
devildevil
Feb 12, 2012 10:10 AM
