FS[Northeast]: Mitsubishi Evolution Evo 8 motor 4g63 turbo short block BUILT
Built 4G63 turbo short block ..motor has zero miles never ran..will handle 600 plus horsepower
Ross forged Piston (8.8:1 comp ratio std bore PTW clearance .005 ..Top ring .019 Sec ring .023
Top of the deck has been hand lapped and checked for straightness
Manley H-beams rods
Eagle crank..std size also micro polished
Honed,Hot tanked,brand new oem freeze plugs
Acl race main, rod and trust bearings std size
(4)oem oil jet squirters
Brand new evo 6 water pump and water pipe
Rear main case and oem rear main seal
Asking $3200 for everything above
**Parts which are not included but can be for about half of what they cost new
*Oem Mitsubishi oil pump with gears (has 40k miles but has all new gaskets installed $235
*Oem balance shaft removal kit $66
*Oem oil pan (used but in great shape $189
*Oem oil pick up $30
*Oem front oil cover gasket $15
*Oem oil baffle plate $23
*Oem crankshaft spocket $43
*Oem small crank shaft spocket $40
*Oem Mitsubishi Rear Main Seal Housing $18
*Oem tensioner $125
*Oem pulley tensioner 40
*Oem timming idler pulley $44
*Oem timming tensioner arm $40
*Oem crank sensor $96
*Oem Cylinder block bracket $170 timming belt side
These part above I have are not new but like new..I just wanted to put the prices next to them so you can see it adds up to over $1000 ..If you buy the short block I will work out a killer deal..just let me know what part's you need
*Can also have this all installed so when you come its a complete short block assembled ready to drop a head on and go
**SERIOUS buyers only will work out a deal if you want a complete bottom end ready to install with the oil pan sealed and all
Asking $3200 which if you went to buy this same built short block will run you $5000 cause there's an $1800 core charge..I'm selling for $3200 no core charge..This is my personal motor I had built for myself but could use the money for other things right now ..PM me for more info and again serious buyers only and local pick up only in yonkers ny 10710 thanks
Manley H-beams rods
*Oem tensioner $125
05-EVO-GSR
Feb 10, 2017 12:25 PM
real fast
Apr 15, 2016 05:28 PM
WTB[West]: 4G63 Bare block or built block
evo.matt
Sep 2, 2014 08:10 PM
Phoenix*
Dec 12, 2011 08:23 PM
allmotorking
Dec 5, 2008 02:37 PM
