FS[Northeast]: Mitsubishi Evolution Evo 8 motor 4g63 turbo short block BUILT
Old Feb 22, 2016, 10:30 AM
real fast's Avatar
Built 4G63 turbo short block ..motor has zero miles never ran..will handle 600 plus horsepower
Ross forged Piston (8.8:1 comp ratio std bore PTW clearance .005 ..Top ring .019 Sec ring .023
Top of the deck has been hand lapped and checked for straightness
Manley H-beams rods ..I also have manley turbo tuff rod's if some one wants to make big power (over 800whp)..price will be $500 extra if you want those rod's installed
OEM crank micro polished .10 under
Acl race main, rod and trust bearings .10 under
Honed,Hot tanked,brand new freeze plugs
Acl race main, rod and trust bearings std size
(4)oem oil jet squirters
Brand new evo 6 water pump and water pipe
**Parts which are not included but can be for extra
*Oem Mitsubishi oil pump with gears (has 40k miles but has all new gaskets installed $235
*Oem balance shaft removal kit $66
*Oem oil pan (used but in great shape $189
*Oem oil pick up $30
*Oem front oil cover gasket $15
*Oem oil baffle plate $23
*Oem crankshaft spocket $43
*Oem small crank shaft spocket $40
*Oem rear main seal $22
*Oem Mitsubishi Rear Main Seal Housing $18
*Oem tensioner $125
*Oem pulley tensioner 40
*Oem timming idler pulley $44
*Oem timming tensioner arm $40
*Oem Cylinder block bracket $170
All machine shop work has been done by storm crankshaft
These part above I have are not new but like new..I just wanted to put the prices next to them so you can see it adds up to over $1000 ..If you buy the short block I will work out a killer deal
*Can also have this all installed so when you come its a complete short block assembled ready to drop a head on an go..parts that are not included totals up to over $1000 ..
**SERIOUS buyers only will work out a deal if you want a complete bottom end ready to install with the oil pan and oil pump sealed and all
Asking $2850 which if you went to buy this same built short block will run you $5000 cause there's an $1815 core charge..I'm selling for $2850 no core charge..This is my motor I had built but need the money right now for other things that have came up ..PM me for more info again serious buyers only and local pick up only in yonkers ny 10710 thanks
Attached Thumbnails Mitsubishi Evolution Evo 8 motor 4g63 turbo short block BUILT-36.jpg   Mitsubishi Evolution Evo 8 motor 4g63 turbo short block BUILT-39.jpg   Mitsubishi Evolution Evo 8 motor 4g63 turbo short block BUILT-42.jpg   Mitsubishi Evolution Evo 8 motor 4g63 turbo short block BUILT-24.jpg   Mitsubishi Evolution Evo 8 motor 4g63 turbo short block BUILT-23.jpg
Mitsubishi Evolution Evo 8 motor 4g63 turbo short block BUILT-25.jpg   Mitsubishi Evolution Evo 8 motor 4g63 turbo short block BUILT-5.jpg   Mitsubishi Evolution Evo 8 motor 4g63 turbo short block BUILT-31.jpg   Mitsubishi Evolution Evo 8 motor 4g63 turbo short block BUILT-storm-crank-card.jpg
real fast is offline
Old Feb 25, 2016, 07:23 AM
real fast's Avatar
Still for sale $2800
Old Mar 7, 2016, 07:15 PM
real fast's Avatar
Still for sale
Old Mar 11, 2016, 05:34 PM
real fast's Avatar
Still for sale
Old Mar 14, 2016, 06:03 PM
real fast's Avatar
Pending Sale
Old Mar 14, 2016, 07:05 PM
saxon's Avatar
ill buy the turbo tough rods
saxon is offline
Old Apr 7, 2016, 07:38 AM
Mottballa74's Avatar
sold or still available?..
Mottballa74 is offline
Old Apr 7, 2016, 03:43 PM
Projectjdm's Avatar
Still for sale?
Projectjdm is offline
Old Apr 15, 2016, 05:28 PM
real fast's Avatar
******SOLD*******real fast;11579728]Built 4G63 turbo short block ..motor has zero miles never ran..will handle 600 plus horsepower
*Oem tensioner $125
Asking $2850 which if you went to buy this same built short block will run you $5000 cause there's an $1815 core charge..I'm selling for $2850 no core charge..This is my motor I had built but need the money right now for other things that have came up ..PM me for more info again serious buyers only and local pick up only in yonkers ny 10710 thanks[/QUOTE]
05-EVO-GSR
Feb 10, 2017 12:25 PM
real fast
Feb 9, 2016 06:59 PM
evo.matt
Sep 2, 2014 08:10 PM
Phoenix*
Dec 12, 2011 08:23 PM
allmotorking
Dec 5, 2008 02:37 PM
Quick Reply: FS[Northeast]: Mitsubishi Evolution Evo 8 motor 4g63 turbo short block BUILT
