[FS] Evo 8 Turbo, TurboSmart IWG
Old Mar 24, 2016, 01:19 PM
W0LF's Avatar
I have the following items for sale located in 41005:
Used Evo 8 turbo with 9.8 hotside - $120obo
Used Turbosmart IWG75 w/22psi base spring pressure - SOLD
The Turbo is off of a 04 Evo 8 with approximately 70k miles on it. The Turbo needs rebuilt. Not entirely sure what all needs done, but I suspect an oil seal. There is shaft play too. The 9.8 hotside has no signs of any divider cracks/etc. Only 1 stud is broke where the hotside mounts to the manifold as seen in the pictures. Water lines are included. Price is $120obo.
The Turbosmart IWG75 Wastegate is for use on the Evo 4-8. It has a base spring cracking pressure of 22psi. Has only about 1,000 miles of use. There are a few nicks/scratches as seen in the pictures from removal. The wastegate itself can be rotated so that those scratches/nicks are not visible from the front by removing the 2 mounting nuts and flipping the wastegate. The turnbuckle is also sightly bent but is still able to be mounted without hassle. The nut is currently un-tightened to allow pre-load adjustment. The mounting bracket may be modified to allow install on an Evo 9 turbo. SOLD
W0LF is offline
Old Mar 24, 2016, 02:52 PM
kyoo's Avatar
FS posts on EVOM MUST INCLUDE:
PICTURE OF THE ITEM WITH A SIGN CONTAINING THE DATE AND YOUR EVOM USERNAME.
Price
Accurate description of item and its current condition.
Location of seller & Willingness to ship.
If applicable VIN number - Transmissions, Shortblocks, body parts which have VIN numbers on them. A picture of your username/date next to the visible VIN number is required. VIN should also be in the FS post in plain text.
kyoo is offline
Old Mar 25, 2016, 03:41 PM
W0LF's Avatar
Pic of both items together.
W0LF is offline
Old Apr 11, 2016, 07:26 PM
W0LF's Avatar
Bump
W0LF is offline
Old May 17, 2016, 07:27 PM
W0LF's Avatar
Bump. Items are still available.
W0LF is offline
Old May 26, 2016, 05:27 PM
W0LF's Avatar
Bump.
W0LF is offline
Old Jun 20, 2016, 07:24 PM
W0LF's Avatar
Bump
W0LF is offline
Old Jul 28, 2016, 07:50 PM
W0LF's Avatar
Bump
W0LF is offline
Old Aug 14, 2016, 07:54 PM
W0LF's Avatar
Bump
W0LF is offline
boyvang
Apr 26, 2018 09:49 AM
FilthyEvo
Aug 7, 2015 07:54 AM
Quick Reply: [FS] Evo 8 Turbo, TurboSmart IWG
