razorlab's simple build(s)
#421
I am in the same boat as you Bryan... my old 2.4L was making a horrid ticking noise for like 3 years... I finally bit the bullet and ordered a new short block and had a shop do the labor... mind you my brother is the shop manager at a hot rod shop and I am pretty familiar mechanically with these cars, we were more than capable of completing it in a relatively short manner, but neither of us had the extra time, (me in the Navy on sea duty & my brother finishing his 29 model A cash rod)... thankfully I was super patient and held off until I built up the slush fund a bit more to have Spec-Ops take care of the labor...
Here is a pic of his car completed... worked on that quite a bit with him as well...
#425
before making any build decisions, you need to pull the head off...
that said, i would be surprised if you cant/dont just strengthen up the bottom end for a bit of coin, and leave unnecessary stuff alone...
#427
If you go the OEM engine route, would you consider a pre loved unit out of a totaled car?
That's how I get my engines and I've dealt with a local company that deals with totaled cars, depending on the mileage you could get a long block (VC to oil pan) for around $3-3500. The engines come out running and they do warrantee if there's a unforeseen issue.
#428
#429
There are a few long blocks on ebay for around $3k right now as well. This one even has video...lol.
http://www.ebay.com/itm/Mitsubishi-E...NW9Ws7&vxp=mtr
#431
The 08's have a provision for a upper chain guide that was deleted in 2010+ and the casting is also cleaner 2010+ but it doesn't affect the runners or combustion chambers.
Other then that is the exact same head.
RazorLab (May 12, 2016)
#434
Wow, it's been almost four months now.
Things are finally starting to move forward. Even if slowly.
Started getting parts for the build and the local shop should have space for the car mid to late September...
So far, parts in the trunk:
Kelford 214-B cams
Kelford springs
ARP head studs
with more to come....
Kelford 214-B cams
Kelford springs
ARP head studs
