razorlab's simple build(s)
#662
interesting setup - cat, mini muffler, mini muffler, full sized?
I'm always thinking about quieting down the car - I've got a cat (200cel mil.spec), which goes to a very decent sized muffler, im going to add a vibrant ultra quiet resonator to see if that does anything, hopefully without going to a mini muffler. I ran the dual muffler setup on my old car (muffler instead of cat, full size muffler) and it seemed fairly decent
1.) Straightpipe did NOT cause an exponential increase in sound. My 5 year old was still fine.
2.) Straight pipe DID allow a lot more timing and less fuel than 100 cell cat. It was shocking how far the knock threshold moved. This was all on Mobil 93.
Jaraxle
#664
I've officially lost patience. I have no idea why this damn thing has taken nine months to date.
Shop told me eight weeks ago that it would be two more weeks. Every question since then around time line hasn't clearly been answered or just danced around.
I'm actually not sure what to do now... ughhhhh.
#665
That sucks to hear man. Are they close by? Would going down there and applying a bit more pressure possibly help?
I'm sure you've spent a boat load a cash on labor if they're wiring up all of your datalogging stuff. Doesn't make sense why it would get so delayed.
![Frown](https://www.evolutionm.net/forums/images/smilies/frown.gif)
#666
Disassembly/reassembly of engine (sleeved built block, upgraded oil pan, kelford cams, DF cam phaser)
Turbo kit installation (turbo, manifold, downpipe, intake)
MAP Oil cooler installation
Firewall heatshield installation
Master Cylinder installation
Clutch installation
Welding in one mini muffler in the catback
^ That's the list. How that is taking nine months I have no idea. I've lost patience and moving into pissed off.
#667
They aren't. I'm wiring everything up whenever I get the car back.
Clutch installation
Clutch installation
Dude, that's ridiculous. That's like 1-2 weeks of work, and then add machine shop time in between.
#671
I SPY worm gear clamps! Many moons ago I had one of those clamps skip a few slots and the leak was so bad that I lost a 4g63 on a dyno (they were idiots doing the dyno session though - at a car show).
Swap those puppies for some solid T-bolt stainless clamps
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
~Jaraxle
#674
![lol](https://www.evolutionm.net/forums/images/smilies/lol.gif)
On a different note, my MR is my daily so I have been considering just buying an OEM shortblock and building it on the side. I do all my work, but measuring and filing ring gaps and putting a block together is probably where I should draw the line (since I have done it ZERO times
![Crap](https://www.evolutionm.net/forums/images/smilies/crap.gif)
What are the shops out there to trust for a 4b11 build these days ?
Two gigantic names that come to mind: AMS, Buschur ?
How did you come to use the shop your using?
~Jaraxle
