Buschur Racing Electric steering
Old Aug 12, 2014 | 06:36 PM
EvoDan2004's Avatar
Originally Posted by golgo13
Why do his kits come with used pumps?
because new they are like 1700.00
Old Aug 12, 2014 | 07:16 PM
rawkus's Avatar
Do you know what car the pump is out of?
Dan
Old Aug 12, 2014 | 07:28 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Just... Wow.
Old Aug 12, 2014 | 08:14 PM
alpinaturbo's Avatar
Porsche Cup cars
Old Aug 13, 2014 | 04:43 AM
mouseIX's Avatar
Originally Posted by alpinaturbo
Porsche Cup cars
I have access to Porsche motorsports parts. Let me see if if it's something they produce (have manufactured then resell) or if I can source it from the supplier to Porsche.
Also if someone gets this please post what accessory drive belt was used.
Old Aug 13, 2014 | 09:16 AM
xXANCHORMONXx's Avatar
guys. you can fit these pumps almost anywhere. dave just made it ''hidden'' to clean up the bay, shorter lines, less nose weight. im sure other reasons too.
if you have ABS and it does not fit then have lines made and mount it were you just removed the OEM pump. yea it will look funny but ask your self WHY did you want this mod. less weight? less drag? well you still get that benefit.
Of course! I just want to try to do my best to bolt it in with what he includes.
It is coming in the mail today so I will update this later with my findings.
Old Aug 13, 2014 | 10:34 AM
mouseIX's Avatar
I spoke with a local shop that has good connections with Porsche Motorsport. Late production 996 cups came with the electric power steering pump. All 997 cups had the system, unless it was not optioned. But they cannot recall if they ever saw a 997 cup without it. I'm checking with them on sourcing a pump new and used. Just curious on the price.
Good luck with the install and I'd love to see detailed pictures of the kit. Did you find a belt yet?
Old Aug 13, 2014 | 08:42 PM
TommiM's Avatar
Im curious to know what belt would work if one already has deleted a/c as well.
Once you get this installed post up some pics. The ones on Buschur's website aren't very detailed.
Old Aug 13, 2014 | 11:18 PM
So after this test fit I've come to some conclusions.
This kit will only work with AC deleted. One of the lines will hit the upper portion of the pump (from what I could see on a bone stock customers car).
This will totally work with ABS.
You must remove your intake manifold to do this, it may be possible to do without but your just going to make it harder for yourself.
Here's what comes in the box
This is it all laid out.
-Pump with ground wire, alternator power wire and signal wire.
-Low pressure line
-High pressure line
Here's a pic of it mounted in my buddies Evo 9, he already has is intake manifold pulled.
I should get it mounted up in my car tomorrow hopefully with more pictures.
Only thing I changed on here was putting a bead in the stainless steel hardline that's included. It is the low pressure line but I'd rather be safe than sorry since I have the tool.
Here's a better picture of the bead.
I'll update this as I go.
Old Aug 14, 2014 | 07:57 AM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Cool.
Old Aug 14, 2014 | 09:44 AM
211Ratsbud's Avatar
Cool.
Yup on my to do list ..
Old Aug 14, 2014 | 02:35 PM
nollij's Avatar
The newer pumps come with a little catch can attached to the cap mounted higher than the reservoir because these pumps like to belch a little bit when they get hot.
The pictures I have seen from Buschur indicate that the pumps he is selling are the older model pumps. Just be aware that this can be an issue.
Old Aug 14, 2014 | 03:33 PM
Good to know, seems like that can be added fairly easily
Installing it now. That oem feed line is a ***** to get to with the trans and tcase there. Pics to come later..
Old Aug 15, 2014 | 12:16 AM
Chris P.'s Avatar
Thompson Ramo Wooldridge
TRW Automotive out of Livonia, Michigan
Electrically Powered Hydraulic Steering (EPHS) Motor Pump Unit (MPU)
http://www.trw.com/steering_systems/...aulic_steering
These are TRW JER100
They are used in everything from Euro Fords, Vauxhalls, Porsche Cayennes, VW, and Skodas.
There are numerous variants of the pumps with different electrical connectors for different OEMs; JER111, JER112, etc.
With a new version/model for higher pressure/resistance of SUVs starting around JER153.
JER100
JER115 (different terminal connectors & reservoir)
JER153
edit2:
I just noticed in the pictures of the kit you just received... did Buschur seriously just shave/sand off the TRW logo off of the reservoir?
Old Aug 16, 2014 | 07:34 AM
JER100
JER153
edit2:
I believe so lol
Also I believe I know why Buschur did not included an accessory belt. I'll be posting pics in the next couple days.
Quick Reply: Buschur Racing Electric steering
