1 Step Colder Spark Plugs -- EVO IX
Can anyone tell me which spark plugs will fit the EVO IX that are 1 step colder? I have searched and haven't foound anything besides greddy and HKS making them and them costing $100 for a set. Aren't there any NGK's Iridium's or coppers that are 1 step colder that fit the EVO IX?
thanks.
thanks.
Same as stock, but with an 8 instead of a 7... Why do you want colder plugs?
thanks.
thanks.
Originally Posted by rcheung
If the mods you have are only the ones in your sig then you would probably be better off with the stock heat range plug.
I also added them when i got meth but they didnt last long the car was misfiring on the dyno up top so i went back to stock heat range and got rid of the misfire. Got my step colder plugs from axiom power
There is tons of plug info on here. Here are a few threads to start:
https://www.evolutionm.net/forums/sh...d.php?t=165134
https://www.evolutionm.net/forums/sh...ighlight=plugs
Personally, I prefer NGK...and they make about every plug you could possibly want.
Cheers!
Ethan
Cheers!
Ethan
I recently got a m1 flash from jestr, and it was knocking a bit so figure to take care of that i should buy a set and throw them in there to see if it helps a bit. I was considering coppers, any part specific part numbers on these plugs?
Axiom power is charging a bit much last time i requested a price for these plugs so thats a no go...
Cheers!
Ethan
Cheers!
Ethan
HKS Part number: S40iL
OE NGK number: ILFR7H
Stock Plug= NGK ILFR7H Stock #5245 LINK
Step colder= NGK R7437-8 Stock #4901 LINK
2 Steps colder= NGK R7437-9 Stock #4654 LINK
3 Steps colder= NGK R7437-10 Stock #4655 LINK
NGK ILFR7H (OEM) Iridium
http://www.sparkplugs.com/more_info.asp?AAIA=&pid=20451
NGK LFR7AIX Iridium
http://www.sparkplugs.com/more_info.asp?AAIA=&pid=16602
NGK LFR7AIX Iridium
Although there is limited discussion on IX plugs, the info applies to choosing brand/type of plug and discusses the need for changing heat range...which applies across engine types. It's also to show that choosing plugs should be the product of careful research and consideration of needs/design.
That said...you're welcome, and good luck!
Ethan
Ethan
Again, most of those threads are for the EVO VIII plugs which dont apply to the IX...but thanks though!
Done
210
Apr 4, 2015 10:47 PM
Hi Im Vinh
11
Aug 26, 2013 09:20 AM
_EVOlved_
67
Mar 7, 2008 05:10 PM
