Ft Hood Evo Check-in
#2256
Yeah I will be using the stock clutch. I am on a huge budget so I bought a new OEM replacement Exedy disc. So all i need to do is have that dropped in. I dont think the fly wheel will need to be resurfaced. The car is babied and its slipping a little bit. So it should be fine.
#2258
For my X?
I have done it before, let me know if you need a hand its very easy to do. When I get another VIII or IX I will be installing them myself. I will be using Kelfords again.
Petty:
You should of told me you were using a stock clutch. I have a stock clutch and flywheel that only has about 3500 miles on it.
Petty:
#2261
#2263
Petty:
You should of told me you were using a stock clutch. I have a stock clutch and flywheel that only has about 3500 miles on it.[/quote]
What year car is the clutch and flywheel for? Cause I might be able to use the flywheel, if my flywheel isnt damaged. My car is an 06 IX btw
