Ft Hood Evo Check-in
#3445
Im gonna jack it up tomorrow and take the sensor out and see if the wires are intact still because everything inside is connected correctly. I put my walbro in and my sending unit wasn't reading fuel. But it turned out the little small metal clip that rides on the rheostat was pushed up in the plastic somehow and wasn't making contact. also the forge unos mbc is ftl so far. Its turned all the way down and it keeps hitting uber high boost and its hooked up correctly. It's an old style so idk if it can be disassembled and it doesn't look like it. I should've just bought a new one damnit
#3448
do you know what kind of spring is in there? The last owner might of changed it so he can run more boost. Also chekc and see if it is a ceramic ball or plastic one, even the smallest thing makes a big difference on MBC's.
#3449
its levar's old mbc so idk wat he ran in it but he said he had it on 24 psi before no problems and its the old style unos so idk if it can be dissasembled. I dont c anyway of doing so but I could just be blind.
