South Region Includes AR, LA, MS, NM, OK, TX, NE, KS.
Ft Hood Evo Check-in
Old Nov 21, 2010, 02:00 PM
  #5716
ssg_petty_210's Avatar
Originally Posted by Boost_Inspired
I ran a 12.4 @ 114 twice with a weak 2.0 60 ft. I had the 2 step set at 4500 to try and be easy on the clutch / learn how to launch it. I was spinning my *** off in 1st and goin into 2nd. After I let the car cool down for another pass I raised the 2 step and started the car and my wbo2 readings were all over the place at idle. even tried doing some driving and it was saying I was full rich or full lean and stuff but my drivability didn't change. So I know the sensor has to be ****ed up. Even logged it on evoscan just to check and its matching what the gauge is saying. At a better track I think I could touch an 11.9 possibly with a good 60ft. I was hoping for a 116ish trap though.
You did a good job running the car, and your time are not bad. But I will say this. Temple track is garbage. There is nobody in in the Evo Community that has been racing cars around this area as long as I have. I have over 11 years racing at the cheap temple track. Everyone and their mothers can attest that the track is garbage. I plan on hitting up SA track soon. You are more then welcome to join me. When I had my turbo civic, I was running mid 13's in temple, to running 12.54 in san antonio. That was in my SOHC D17 on spray. You will def run a better time at a better track. So whoever runs at the temple track, and are upset about their times. Get to a better track, and you will be much happier. Dont get your heart set on your time if it came from Little River.
Old Nov 21, 2010, 03:43 PM
  #5717
Boost_Inspired's Avatar
ya ive been racing there about 5 and ya it sux major *** , seguin and ennis are really good tracks and well worth the drive. Whenever u head down to seguin and if my clutch is in ill be down to go down with u
Old Nov 21, 2010, 04:08 PM
  #5718
Evostacio's Avatar
U should launch at 5500 when u come to sa cause if u think u will spin at 4500 it won't. It's gonna die on u the sa track works very well with evos and low tire pressure. So u might wanna up the 2 step. But if u wanna try it at 4500 go for it and if u don't know how to change it let me
Know I'll help u out with changing ur two step
Old Nov 21, 2010, 04:12 PM
  #5719
ya I will definitely raise it back to 5500 which is already done , what tire pressure do u run on your street tires. I dropped em to 25 but didnt get a chance to see if it made a difference due to my wideband issues.
Old Nov 21, 2010, 05:17 PM
  #5720
Stacio is right about the SA track. Its an awesome track though. Little river just sucks butt period lol. Where is seguin at?
Old Nov 21, 2010, 05:28 PM
  #5721
Isn't that where San antonio raceway is at? Like 15-20 mins outside SA city limits?
Old Nov 21, 2010, 06:21 PM
  #5722
Evostacio's Avatar
Yeappppp and I drop them to 18psi
Old Nov 21, 2010, 06:29 PM
  #5723
kk well i should be ordering my clutch in less than a month then once that bad boy is in ill be looking for a weekend to go to san antonio raceway
Old Nov 21, 2010, 07:07 PM
  #5724
monkey_187's Avatar
What clutch are you going to get?
Old Nov 21, 2010, 07:27 PM
  #5725
im not gettin the fidanza now frank called up one of his guys and they told him there are tons of returns on the model i wanted and not to get it so ima get an exedy stage 2 4 puck, gonna get it through Adam at MAP
Old Nov 21, 2010, 07:39 PM
  #5726
monkey_187's Avatar
Adam will give you the best deals around, call him Superman, he will know what I'm talking about.
Old Nov 21, 2010, 07:46 PM
  #5727
ya i already got a price from him and its dope as **** so ima hop on that
Old Nov 21, 2010, 08:00 PM
  #5728
lancersibling's Avatar
Let me know when you roll to SAR! I'm in. It is a good track!!
Old Nov 21, 2010, 08:06 PM
  #5729
monkey_187's Avatar
I told you before that I knew where you could get the best deals around.
Old Nov 21, 2010, 08:27 PM
  #5730
monkey_187's Avatar
Originally Posted by wariosport
That's good that way! You don't want to hang out with a bunch of pu$$ies!
Quick Reply: Ft Hood Evo Check-in
